Author Topic: Laid down on it's side  (Read 5928 times)
Offline hummbug
« on: July 21, 2012, 05:42:09 PM »
71 - CB500, all standard except for Dyna ignition and coils. Oh yeah and exhaust is 4-1.
So....this is slightly embarrassing. I was out for a ride and stopped to take a photo of a cow...yep.
When I went to start the bike again, I did so in haste, without checking for neutral. It was in gear and kicked forward, putting me off balance and I laid (not dropped) the bike on its side. The side of the road was quite steep but luckily covered in grass so there was no damage to the bike.
However, after lifting the bike back upright and starting her again, there seems to be the symptoms of vapour lock - the engine, under load, won't rev above 5k rpm.
I did a quick test on the air filter by removing it and riding down the road  - no change in symptoms.
After that I limped it home at 4k rpm , drained the float bowls with no change in symptoms.
So, before I go and check my fuel cap vent, drain the petcock and perhaps pull the carbs, does anyone have any ideas for what may have occurred when the bike went down on it's side? My guess is the carb float levels got all messed and/or there was some gunk in there that got mixed up and is blocking something the jets...??
« Last Edit: July 21, 2012, 06:42:00 PM by hummbug »
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
Re: Laid down on it's side
« Reply #1 on: July 21, 2012, 06:24:48 PM »
If the bike was running, you may want to change the oil, not that that causes vapor lock, but it is a good idea.  Gas can get in the oil.  Maybe you were close to a change anyway?  Just don't kick the starter over to 'empty out the last drops from the motor.'  ;)
« Last Edit: July 21, 2012, 06:26:28 PM by Greggo »
Offline hummbug
« Reply #2 on: July 21, 2012, 06:41:29 PM »
Just did a change about 20 miles before this... thanks though I will put it on the list. It wasn't running when it tipped over, I pressed the starter button while it was in gear.
No kick starter on the bike anymore, but that's another story.
« Last Edit: July 21, 2012, 06:44:08 PM by hummbug »
Offline Greggo
  • Somebody's
« Reply #3 on: July 21, 2012, 06:46:12 PM »
Well, just kick it over a bunch with the kill switch 'off' and then run the hell out of it.
Offline Old Scrambler
« Reply #4 on: July 21, 2012, 06:53:33 PM »
One or more of the floats may be stuck ???.......somehow the chokes are on ??? .....We've all done something similar 8) 8) 8) 8) 8)........Regarding the cow....I used to take my uncle (long time dairy farmer) for a drive in the country and he would admire farmer's prize herds in the field.....occasionally he would say "what a bag!"  So now you have to post the picture ;D ;D ;D ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #5 on: July 21, 2012, 06:58:03 PM »
Check the exhaust headpipe temps with a damp rag or something to see which floats may be stuck or which cylinders are not cooperating for starters.
Offline rboe
« Reply #6 on: July 21, 2012, 07:00:38 PM »
I've stopped to take pictures of cows, and I have dropped the bike. At a rally in front of forty plus guys. It was fully loaded so I needed about eight guys to pick it up so in that regard I was lucky to have so much help right there. I needed it!
Wrap the carb bowls with a plastic handled screw driver to shake loose the carb floats. And run her. :)
1974 CB350F
2008 XR650L
2012 Griso SE
Past iron
1971 Suzuki TS125
1977 Honda CJ360T
1981 Kawasaki 550Ltd
2000 Moto Guzzi Quota
Offline hummbug
« Reply #7 on: July 21, 2012, 07:32:31 PM »
OK, well, it's actually a bull I think, not a cow...you get the gist.
So I've just drained the petcock bowl and have discovered that its not shutting off properly - may have to invest in some new fibre washers I think. No real gunk in there to speak of, perhaps a few specks.
I have taken the fuel cap off given it a clean and its drying at the moment. I have tapped the side of all the carb bowls but might give it another go today.
@rboe - I'm glad you had someone to help you pick it up. My bike wasn't packed at all and to lift it by myself was a bit of a strain on the steep roadside. Woke up a bit tight in the old shoulder this morning. Don't ever want to put it down like that again.
I think it's time to rebuild the carbs again though - those, along with the leaky petcock.... and get it right this time.
Offline hummbug
« Reply #8 on: July 21, 2012, 09:50:32 PM »
I went for a ride and saw no difference. I stopped half way and opened the gas cap - no change.
Checked temps on all headers - by feel they are all the same. It runs smooth out to 4k rpm and then starts to falter - like fuel starvation. Seems that perhaps the main jet/s are blocked perhaps. To be honest, I've rebuilt the carbs once before about 12 months ago but they are technically still a bit of a mystery. Maybe that's the problem.
So, my guess is that I need to pull the carbs, check them all out inside, put new washers in the petcock, sync carb and then see what happens.
I needed to do it anyway...now I just HAVE to do it.
Offline rboe
« Reply #9 on: July 21, 2012, 09:58:08 PM »
Operate the throttle while staring at the carbs. Sounds like you bent or jammed something preventing full throttle. But that is just a wild ass guess on my part.
1974 CB350F
2008 XR650L
2012 Griso SE
Past iron
1971 Suzuki TS125
1977 Honda CJ360T
Offline hummbug
« Reply #10 on: July 21, 2012, 10:12:50 PM »
thanks rboe - checked that but it's all working as it should  - something internal I think.
Offline harisuluv
« Reply #11 on: July 21, 2012, 11:04:28 PM »
What side did it fall on?  If it just was laid down and then suddenly wouldn't run right the carbs wouldn't seem like a likely culprit.  Maybe you dropped it on the right side and the points are off a bit?
« Reply #12 on: July 21, 2012, 11:11:10 PM »
+1 maybe a small dent in the points cover?
« Reply #13 on: July 21, 2012, 11:21:54 PM »
ill go with some fine debris disturbed,,you might get away with just dropping the bowls and jets,remove the air screws and going for it with the air compressor every which way,,id do that before pulling the carbs off!unless you want to anyway?
Offline trueblue
« Reply #14 on: July 22, 2012, 05:05:49 AM »
+2, I would check this before going on a massive search through the carbs, it is a lot easier to check the points then move to the carbs, than to go the other way.
1979 CB650Z
Offline Bailgang
  • Scott
  • Indiana
« Reply #15 on: July 22, 2012, 05:30:51 AM »
Well he did say it had a dyna ignition rather than points but if there is a ding on the points cover from the fall then I'd be checking it out anyhow.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline Steve_K
« Reply #16 on: July 22, 2012, 06:23:13 AM »
If it fell on the throttle side the grip may have been pushed against the bar.  That can make the throttle turn hard.   BTW, that cow could be a steer, an unlucky bull.
Steve
Steve_K
Offline hummbug
« Reply #17 on: July 24, 2012, 01:36:49 AM »
thanks for all the answers...
It fell on the left side so no points cover damage - in fact it didn't really fall, I managed to hold onto it as it went and more laid it in the grass. It felt like ages but it probably only stayed there for 30 secs before I managed to heave it up.  The hand grip took the brunt of the impact and had a little grass stain on it...
 I do have dyna ignition too so points are a moot point.
dave500 - I need to do some work on the carbs anyway so I'll pull 'em.  Probably won't bother until I get back from holidays in mid-Sept though.
Bit of a shame, the bike was running nicely until this...
If, after that it's still not back to it's good old self, I'll have to investigate other causes....or push it into a river.  It's a 50/50 decision at the moment as I'd prefer to be riding more than I have lately.  I mean fixing these things is fun and all but riding is far more interesting.
Offline ChuckG750f1
  • Not your average, everyday, run-of-the-mill
« Reply #18 on: July 24, 2012, 05:54:48 AM »
This may be stupid, but what about an air restriction?  Could something be blocking your airbox intake inside?  Just a trying to think what could cause this if fuel wasn't the problem.
Life is hard; it's harder if you're stupid.
- John Wayne
1976 CB750 f1
1995 HD Softail Custom
Offline hummbug
« Reply #19 on: July 24, 2012, 05:58:13 AM »
Good point Chuck I may take another look  down there - i did take the air filter out and go for a quick ride to no avail so it's hard to see what else could be restricting the air intake but hey, stranger things have happened... I also have to wait until the weekend to work on the bike - I'll have another look at it on Saturday.
Cheers
Offline ChuckG750f1
« Reply #20 on: July 24, 2012, 07:02:59 AM »
Hummbug- Off topic, I've been to Melbourne twice in the mid/late '80s.  I was working but I had a chance to go down to the coast one day (12 Apostles area, I think it was called).  I also was up in Brisbane working.  There I spent a day hiking in a park (Bina Bura?).  10 days both trips. -Chuck
- John Wayne
1976 CB750 f1
« Reply #21 on: July 24, 2012, 01:46:36 PM »
i live close to binna burra,in the hills,great riding.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #22 on: July 24, 2012, 02:57:44 PM »
Mooooooo
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline ChuckG750f1
« Reply #23 on: July 24, 2012, 04:40:28 PM »
Dave- Keep a sharp eye out for those Goannas, Koala and Wallabies! -Chuck
- John Wayne
1976 CB750 f1
Offline hummbug
« Reply #24 on: July 25, 2012, 12:44:41 AM »
Love the cow pic.
It's a small world hey Chuck. You probably would have travelled down the Great Ocean Road which is actually great except it's very bumpy and cars are everywhere on weekends - not much good for riding if you want to get a hurry up.  There are, however a few great roads leading back up into the hills around that region. It's a beautiful part of the world.
I can't say anything for Binna Burra - never been up there. I'm sure it's great though, except for the banana benders...just kidding Dave, you're actually from down this way aren't you?
