Author Topic: Brake Upgrade  (Read 1877 times)
Offline Douglas.birnbaum
  • Doug B.
Brake Upgrade
« on: July 22, 2012, 04:24:12 AM »
My front main caliper may be out of commission. I snapped the bleeder valve right flush with the unit and getting ready to drill and rethread the hole. If this fails any ideas for a possible brake upgrade where I can use the OEM parts and not pay out the ass?
Thanks
Doug
'76 CB 750A
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
Re: Brake Upgrade
« Reply #1 on: July 22, 2012, 06:22:21 AM »
I don't know of any calipers that will swap over to our fork legs.  I've done a lot of research and always came up empty.  Maybe someone else will chime in.
I'm close to doing a 750F fork swap - that will accept later dual piston calipers - on both sides.  It's a bit bigger/more involved than a simple caliper swap.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline 77Pinto
Re: Brake Upgrade
« Reply #2 on: July 22, 2012, 07:04:47 AM »
What I do with snapped bleeders is weld a nut to it and they come right out.  Not an easy job with on bikes because of the size, but it works.  The heat generated helps.
If you can't do it yourself, you can find a welding shop near you that should be able to.
Bill
  • Doug B.
Re: Brake Upgrade
« Reply #3 on: July 22, 2012, 09:55:34 AM »
Thanks guys... the only way I think to upgrade is to fab your own stuff. If anyone has another caliper that they don't want I'll pay for it. Thanks
'76 CB 750A
Re: Brake Upgrade
« Reply #4 on: July 22, 2012, 08:10:54 PM »
The biggest bang-for-the-buck brake upgrade is to add a second stock caliper and disc. There are a few niggling details, but a dual-disc conversion is worth the effort, IMHO.
Offline 77Pinto
Re: Brake Upgrade
« Reply #5 on: July 23, 2012, 05:12:57 AM »
IIRC: The front wheel hub is different on the dual disc, but I think everything else is a bolt on.
Bill
Re: Brake Upgrade
« Reply #6 on: July 23, 2012, 06:24:22 AM »
Here is some reading on the subject of dual disc setup:
http://forums.sohc4.net/index.php?topic=110116.msg1236864#msg1236864
