Author Topic: PAMCO Ignition  (Read 1149 times)
Offline 72_350_FOUR
PAMCO Ignition
« on: July 22, 2012, 05:59:52 AM »
Hi Guys, i just bought a PAMCO, does anyone know where i get the coils also for my 350f ? I don't see it on that website.
1972 Honda CB350F
Offline 72_350_FOUR
Re: PAMCO Ignition
« Reply #1 on: July 22, 2012, 05:01:19 PM »
anybody ??
1972 Honda CB350F
72500john
Re: PAMCO Ignition
« Reply #2 on: July 22, 2012, 05:13:57 PM »
dyna makes coils that will fit on our bikes. just make sure the ohm value of the primary coil you install is the same as the one you take off. i think it will be 5 ohms. they will use automotive type plug wires to hook into the coils. i bought a set of accell 7 mm wires for a v8 at the local auto parts store and cut them to length. have 4 spares. replace the plug caps while you are at it. they are cheap.
Re: PAMCO Ignition
« Reply #3 on: July 22, 2012, 07:44:02 PM »
Check with CB750 supply. I bought some coils from them.
Offline 72_350_FOUR
Re: PAMCO Ignition
« Reply #4 on: July 23, 2012, 05:28:37 AM »
72500 - your saying to replace the plug caps on the Accel set ?  thanks for the replies guys.
1972 Honda CB350F
72500john
Re: PAMCO Ignition
« Reply #5 on: July 23, 2012, 06:00:44 PM »
i got a set of accel wires from the local auto parts store for a v8 auto engine, they had copper conductors. the coils i got from dyna ( p/n dc8-1) utilize the same method to connect the wires to the coil as a car distributor cap. bought 4 new ngk caps. crimped the wire connectors on to the ends to hook up to the coils. cut the wires to length and screwed on the new ngk caps. best part is i have 4 extra wires and the whole set was around 27 bucks. below are pics.
72500john
Re: PAMCO Ignition
« Reply #6 on: July 23, 2012, 06:06:50 PM »
sorry forget, yes. replace the caps on the acccel set. like i said the set i got was for automotive use so i just cut them off. the ngk ones have resistors built in. i think its 5000 ohms.
