Hi guys, I've finally got going properly on getting this bike going.
Here's what I've done so far:
1. I was looking around for original exhaust replacements but in the end decided to go for Mac 4 into 1s until I find some good ones for not too much.
2. Checked the points gap and the timing and got them set correctly. They were pretty much dead on anyway.
3. De-rusted the inside of the tank. It took me a few attempts because the rust would come back. Evaporust twice, then the toilet bowl cleaner method (worked well) but forgot to rinse with water and baking soda so it rusted again quickly. Finally got it with the toilet bowl method and then some drywall screws for good measure.
4. Carbs: Original carbs with 100 main jet and 38 idle jet. Cleaned the carbs (a few times
) I would put them back on the bike and start it but it was having issues idling well after it warmed up so I'd take the carbs off again and there'd be tiny flecks of rust in the bowls. Unfortunately had to do that a few times. Set the float levels. Bench synced them as well as I could. Replaced the petcock fuel filter with a brand new one from the Honda dealership and also the gas cap seal.
They are not vacuum synced yet because I'll have to take it to a shop for that since I don't have the equipment.
5. Replaced the air intake boots. Purchased them from a member here and they seem very nice.
6. Fixed a couple electrical things in the main console. Still no high beam indicator light however.
7. The front brake was sticking so I took the caliper apart and cleaned out the grunge in the groove where the seal goes. Replaced the brake fluid and bled the brake using a speed bleeder that seemed to work pretty well.
8. I bought tires but have yet to put them on. Went for the Avon Roadriders.
9. There was no air filter when I got the bike so I put in a Uni 4055 stock replacement. There were a couple pieces missing from the air box assembly. I'm not sure how that will affect how it runs. It's the piece in the middle and it's gasket that are missing. I put some foam overtop of the piece on the right.
