Author Topic: Is the 550 wheel centered in the swingarm?  (Read 1838 times)
Offline B.O.X.N.I.F.E.
  • The Stumped
« on: July 26, 2012, 11:44:09 AM »
Having trouble measuring, is the wheel centered in the '77 SS 550 swingarm?
1974 CB550
Forever West
Re: Is the 550 wheel centered in the swingarm?
« Reply #1 on: July 26, 2012, 09:42:12 PM »
 Never assume they are.. measure sprocket off set from center of hub..
  • The Stumped
« Reply #2 on: July 26, 2012, 10:05:51 PM »
I'm guessing you're talking about the countershaft sprocket, right? Sheesh, I don't know if I can figure that out...
1974 CB550
Forever West
« Reply #3 on: July 26, 2012, 10:51:15 PM »
 Measure the width or your rear hub at the spoke flages.. divide that by 2,
 Take from where you measured your hub width, measure from there to the rear sprocket.
 now add that to your 1/2 of hub width.
 Build your new wheel with that same offset to the sprocket, then line the rear sprocket up to the front sprocket, THEN, make your wheel spacers..
« Reply #4 on: July 26, 2012, 11:09:51 PM »
Rim is centered to hub then you need to get chain aligned
  • The Stumped
« Reply #5 on: July 27, 2012, 01:31:29 AM »
The center I had machined was done to the same specs as stock. I'm horrible at measuring, and the machine shop is halfway across the country. If someone knows if the stock wheel is centered, and if not, offset how much and to what side, those measurements would work for my application.
1974 CB550
Forever West
« Reply #6 on: July 27, 2012, 09:16:50 AM »
 Should mention if it were a few or 3mm off, it will still work, but should be corrected soon.. Usually just making spacers..
