Author Topic: 78 f3-my turn signal beeper stopped beeping.Where do I look to fix this.  (Read 1583 times)
Offline lostmykeys
 I know you guys have bigger fish to fry as far as answering questions.
 I just got used to the beep reminding me that my turn signal is on.Both  horns still work.My charging system seems to be working perfect.
 I have noticed while sitting at a light with my signal on.The longer I sit there the slower the blinkers flash and then today the beeper just quit.but the blinkers still work.
Offline CycleRanger
  • No comment about being an
heh, most people would be glad the buzzer stopped! ::)
I hooked mine up when I restored my bike and I hate it but I've been too lazy to disconnect it.
You'll have to open up the headlight to check the wiring.
You can pull the buzzer off and hook it up to 12v to check it.
If it works it may be your flasher relay is going bad.
Replace it with an electronic one if it needs it..
If the buzzer is bad I'm sure someone here has one to sell or they show up on ebay as well.
« Last Edit: July 26, 2012, 08:00:05 PM by CycleRanger »
Offline lostmykeys
thanks,where is this buzzer?
Offline CycleRanger
It's attached to the inside of the left fork ear behind the headlight.
Offline lostmykeys
thats good info thanks!
