Author Topic: Let it all hang out,tell us how you really feel and what pisses you off.  (Read 1396663 times)
simon#42 and 40 Guests are viewing this topic.
Re: Let it all hang out,tell us how you really feel and what pisses you off.
« Reply #21550 on: August 26, 2024, 10:17:55 pm »
Once you get the product you will be free to unload Don. They are deplorable...
John, flame trap design in old 240/740/940 era of Volvo designs could push out seals if not serviced... Luckily you aren't dealing with that. If the separator buried low on the block clogged it was a major problem changing it.
Yours might be something simple and easy once you get into it...
Might just be a valve cover gasket or a hose clamp.
Have you identified if it is oil or other fluid that is leaking? The bad thing is modern cars are very compact in their design and that makes for difficult jobs for people like me with big hands.
Offline Kelly E
  • Geriatric Hooligan
« Reply #21551 on: August 27, 2024, 10:00:52 am »
David, those modern compact designs make it difficult even for little guys like me. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #21552 on: August 27, 2024, 05:47:36 pm »
Yep, I’ve got to replace the timing belt on the wife’s front wheel drive Hyundai. Was supposed to be changed at 50K miles, has now done 95. Bought everything to do it, just don’t want to…. ;D
Online Don R
« Reply #21553 on: August 28, 2024, 12:28:52 am »
 While you're in there take note of the idler bearings, that's what I used to make new ones for my 78 goldwing. I got some funky bolts too, I forget the exact recipe.
« Reply #21554 on: August 28, 2024, 12:40:20 am »
Harmonic balancer as well...
Offline Kelly E
« Reply #21555 on: August 28, 2024, 01:42:30 pm »
Is the water pump buried in there too?
1983 Honda CB 1100F
Offline jaytee-nz
« Reply #21556 on: August 28, 2024, 02:41:36 pm »
Geez - he'll never do it now !
« Reply #21557 on: August 28, 2024, 06:01:11 pm »
Friend's son has ASE automotive certs in 3-4 areas after testing having done high school auto shop in a county school in a neighboring county. He was hired by a local dealer and they have so many engine failures on the cheap K & H cars they as a dealer offer a lifetime replacement for engine failures and the like.. all the engine parts on both the H or K engines are interchangeable and direct fit replacement. Truly horrible quality on the low end car line in terms of low priced models.  The engines have so many problems that engine failures are frequent.
So, be thankful your engine isn't among the new crop and it had some decent engineering. The race to the bottom happens at some and AI couldn't imagine having one of these cars at a dealer where they didn't do it for free and put up a fuss to get out of a claim.
These days water pumps and timing belts and harmonic balancers all get changed at similar intervals.
Offline BenelliSEI
  • 1969 cb750
« Reply #21558 on: August 28, 2024, 07:52:49 pm »
The oil leak in the Volvo C30 turned out to be the oil feed pipe to the turbo. It’s a solid line with banjo bolts and totally rotten. Not touching it until the line, bolts and washers arrive. Looking at the turbo boost control valve, I doubt it can actually be working. Spotted one on Amazon for almost nothing so that will get changed too. I bought this car from a friend that kept it immaculate and then had the dealer offer him $2500 (Canadian) on trade! My wife really likes it, so not scrapping it yet. But it better not piss me off.
« Last Edit: August 28, 2024, 07:57:26 pm by BenelliSEI »
« Reply #21559 on: August 29, 2024, 01:16:53 am »
hey Terry ive done ours 4 or 5 times plus other little front drive cars,remove driver side under splash guard,remove drivers front wheel,jack under engine and remove upper engine mount,youll see how the rest goes easy,ive left water pumps in place for two belt swaps,why throw a good known pump its not that hard to do just the pump,but do check your balancer hasnt slipped on its ring the marks wont line up correctly,i used the same idler for say 3 belt changes,only because its our car.
Offline dhall57
« Reply #21560 on: September 07, 2024, 07:24:19 am »
A lot of people today don't defend what is truly right, they defend only what they like and what will benefit them the most >:(
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Online grcamna2
« Reply #21561 on: September 07, 2024, 11:48:34 am »
I do hate that trend;very rare to see someone stand-up against popular opinion as they all seem to agree,like a mob of uninformed 'sheep'.
« Reply #21562 on: September 08, 2024, 02:57:57 pm »
Thanks Dave, that’s good to know. I contacted the mechanic who did the Roadworthy Inspections on both of my utes and he was talking around $700 to just fit the parts that I bought (new belt kit, idlers, seals, water pump etc, plus the 3 ancillary belts) which I thought was a bit steep, so I think I’ll bite the bullet and do it myself, the weather is getting better here now, so I’ll do it one weekend in the not too distant future and spend the money on hookers and booze instead. Do Hookers still make headers? ;D
Offline jaytee-nz
« Reply #21563 on: September 08, 2024, 06:07:14 pm »
No Terry, "Hookers" don't make headers - they give headers !
« Reply #21564 on: September 08, 2024, 09:47:53 pm »
What? So this is just a scam? Bugger! ;D
Offline BenelliSEI
  • 1969 cb750
« Reply #21565 on: September 17, 2024, 06:12:27 am »
Left the Volvo C30 at the local shop for an oil line replacement. Came home and walked around the back and spotted this! Shop suspects a tow truck that dropped a car a few days ago. Torn right through…..Piss me OFF!
« Reply #21566 on: September 17, 2024, 06:19:50 am »
That is not going to be a cheap fix
Offline BenelliSEI
  • 1969 cb750
« Reply #21567 on: September 17, 2024, 11:37:57 am »
Volvo Canada wants $2000 for a new one! I’ll probably glue it shut and paint it over with a brush. It’s a $2K car……. It doesn’t have another mark on it.
Offline Kelly E
« Reply #21568 on: September 17, 2024, 12:46:49 pm »
Shouldn't the shop be paying for it since the car was in their care and control?
1983 Honda CB 1100F
Offline BenelliSEI
  • 1969 cb750
« Reply #21569 on: September 17, 2024, 02:37:12 pm »
Yes…. Tim (also the guy I race the LEXUS with) has already found a good, used replacement. I’m not that fussed about it. Remember, I smashed the race car is the Spring…… He’ll make it right, for sure.
« Reply #21570 on: September 17, 2024, 03:01:38 pm »
No matter what you paid for a car, it still quite rightly pisses you off John. My 22 year old Ford pickup doesn’t have a mark on it either, but after spending some time (and a fair bit of cash) at the shop I noticed a small dent under the left sill panel that I hadn’t noticed before. If I was a suspicious type I’d guess that they either tried to jack it up in the wrong spot or drove over something like an arm of their hoist, but as I couldn’t be sure that it wasn’t there before I dropped it off, I just let it go. The trouble now is every time I look at the truck I notice the dent and it pisses me off. ;D
Offline BenelliSEI
  • 1969 cb750
« Reply #21571 on: September 17, 2024, 03:02:57 pm »
Me too. I know I will fix it one way or another!
Offline Kelly E
« Reply #21572 on: September 17, 2024, 03:32:24 pm »
Oh, so it was revenge motivated. ;D
1983 Honda CB 1100F
Offline BenelliSEI
  • 1969 cb750
« Reply #21573 on: September 17, 2024, 04:48:31 pm »
Tim went to the towing company and found the truck! Still had my paint stuck to the steel tee bar on the back! They will cover it!
« Reply #21574 on: September 17, 2024, 05:11:38 pm »
Driver of tow truck is pretty oblivious or not a totally honest type to not know he pranged your vehicle
« Last Edit: September 18, 2024, 04:19:40 pm by RAFster122s »
