Author Topic: Let it all hang out,tell us how you really feel and what pisses you off.  (Read 1445702 times)
Offline mick7504
Re: Let it all hang out,tell us how you really feel and what pisses you off.
« Reply #9050 on: October 23, 2015, 05:54:12 PM »
Thanks Terry.
I like the look of those XS1 bars and they were an option that I looked at.
The second lot of bars in the Postie pics are Honda Magna pullbacks (HSB27) and are a good height and width.
The bars on the Quad Bike are comfortable too and are good for control when the Quad starts getting a bit funny and going sideways on the skinny gutted dirt tracks out in the bush.  ;D
If I was you
I'd be worried about me.
Offline petercb750
« Reply #9051 on: October 24, 2015, 12:24:27 AM »
I got a bar looking at Terry's wang..... :-[
1972 750/4 K2 (his), 1976 400/4 (hers)
1982 CB1100RC (ours)
« Reply #9052 on: October 24, 2015, 12:29:08 AM »
That's OK Pete, it happens to the best of us, it's not a gay thing............. I've gotta get it to Jeff at Ace and have him sort out the ignition fault, I could do it myself by replacing the entire ignition system, but he'll probably just find a bad earth and have it fixed in 10 minutes. ;D
Offline mick7504
« Reply #9053 on: October 24, 2015, 02:18:31 AM »
I got a few hours in today to put the 3 Phase compressor back together.
This is the one that that I thought that I'd get real clever with and convert it with a single phase motor.
That turned out to be a fcuking disaster as well as a WOFTAM. (Waste Of Fcuking Time And Money)
But ya gotta give it a go.
So, no worries, we can do that.
PIGS FCUKING ARSE.
That turned out to be a real poofta getting the pulleys aligned.
The horizontal alignment was a piece of piss because the electric motor pulley is adjustable on the shaft.
But getting the axial offset right was enough to turn a bloke to the bottle.
And it did.
When the belt was tensioned, the fcuking electric motor pulley would kick itself outa square with the compressor pulley.
Fcuk it.
Anyway, it's got 8 thou of kick in the axial offset and that's good enough for the bush.
If the fcuking drive belt jumps the pulley now, I know were there's some explosives.  ;D
If I was you
« Reply #9054 on: October 24, 2015, 05:48:10 PM »
That looks beaut Mick, how many CFM? Cheers, Terry. ;D
Offline mick7504
« Reply #9055 on: October 24, 2015, 06:31:29 PM »
It's 26 CFM mate with a 150 litre tank.
The electric motor is 3Ph/5.5HP but I've got no 3Ph grid power here which is why I tried to convert it Single phase with a 15 amp 3.5HP electric motor
but it just didn't have enough grunt to run the compressor motor after 80 PSI.
And that did piss me off because I thought that I'd backed a winner.
So, the options now are either sell it or put a 3 phase outlet on the 12.5 KVA Diesel Genset and crank her up.
There's nothing like a challenge mate especially if it means having a few beers and getting pissed off with these hair brain ideas.  ;D
If I was you
Offline bear
  • Leeton in Australia
« Reply #9056 on: October 24, 2015, 07:03:10 PM »
 :o
I'm not "Pissed Off", but I'm a bit flummoxed.
Please explain this rant to me Uncle Tez.
"Simple question, does a mandatory helmet law comply with the Non Aggression Priciple? It does not, as enforcement would involve the initiation of force against a person who has harmed nobody. The end result of enforcement is caging or killing violators (i.e. if the violator attempts to continue on his was while harming no person or property). Remember every time you think "they should make a law ...", the only tool government has to enforce any law is violence.
Is forcing people to wear helmets worth killing for? Absolutely not. All arguments regarding costs to others are irrelevant. Without the welfare state (the initiation of force) there would be no involuntary costs on others. If you have an argument against medical and ongoing costs in a wreck of a rider with no helmet, then you really have an argument against the welfare state and regulation of the medical sector.
With all that being said, I wear a full face all the time every time. I believe that choice has saved my life twice now. I strongly encourage everyone to wear a full face but would never threaten or use violence to get them to do so under duress."
They must have really good drugs over there . ???
Brian
Offline petercb750
« Reply #9057 on: October 24, 2015, 08:26:02 PM »
It's got me fkd too.
Offline petercb750
« Reply #9058 on: October 24, 2015, 08:28:51 PM »
I'm pissed off about all the double dutch outer Zimbabwe southern Angola language you blokes are talking in....ffs, does it pump up fkn tyres or not...... :-\ :o ;D
Offline mick7504
« Reply #9059 on: October 24, 2015, 09:40:12 PM »
Yeah no worries Pete.
It'll pump the pushbike up no problem.
But you have to be a bit careful mate because if you keep pumping big mobs of CFM's into it, you'll blow the fcuka up.  ;D
If I was you
« Reply #9060 on: October 24, 2015, 10:09:13 PM »
:o
Brian
It's pretty simple actually Brian, he's saying that while he's dead against governments making helmet laws mandatory, (or worse, people riding without helmets being discriminated against by not being covered by medical insurance) he knows that helmets work, and says he's been saved by his own use of a helmet.
Pete, CFM = Cubic Feet (of air) per Minute. Mick's got a beaut compressor, but his 240 volt electric motor doesn't have the grunt to turn the pump once the pressure goes over 80 psi. I think the 3 phase (415 volt) plug on his big diesel generator will do the trick, or send it to me and I'll strap a big briggs and stratton onto it...... ;D
« Last Edit: October 25, 2015, 01:14:26 AM by Terry in Australia »
Offline mick7504
« Reply #9061 on: October 24, 2015, 11:05:31 PM »
The Air Comp is starting to look like the business again.
The 3 Phase motor is wired into the main isolation switch and all that needs to be done now is to fit and hook up the 3 Phase pressure switch.
The old pulley guard is a bit rooted so I'll either try and knock it back into shape or make up a new one.
I bought a new single phase pressure switch when the single phase conversion was in progress so that'll be a spare now.
Now there is a difference between 3 and 1 phase pressure switches and I don't know what the difference is.
Maybe the 3 phase switch has heavier contacts for the voltage leap so the old lad will be going on before it gets fired up for the test run.  ;D
If I was you
« Reply #9062 on: October 25, 2015, 01:17:53 AM »
Good work Mick, I've just arrived in Adelaide, so I'm gonna go find a steak and a cold drink or five.... ;D
Offline krusty
« Reply #9063 on: October 25, 2015, 01:22:21 AM »
Rossi pisses me off. I wont say why for those who haven't seen the race yet.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline mick7504
« Reply #9064 on: October 25, 2015, 01:42:45 AM »
They can knock up a mean steak in Adelaide Terry.
There use to be a bloody good chook shop on Burbridge Road not far from the Airport.
Pete might know if it's still there.
The Bangers and Mash with gravy at that chook shop was a good feed after the pub closed.
That was the staple diet back in the 70's when I was an Adelaide lad.
Cold piss and chooks made the world go 'round.
And Honda 4's too.  ;D
If I was you
« Reply #9065 on: October 25, 2015, 02:15:36 AM »
Ha ha, those were the days Mick, when we were young and bulletproof, CB750's were among the fastest bikes on the road, and we didn't know (or care) what "handling" meant. I'm at the "Mawson Lakes" pub, I don't think Mawson Lakes existed when I was last here, but for under 30 bucks I just ordered a steak burger with the lot, garlic bread,  pint of cider and a pint of coopers, so I'm not pissed off at all..... ;D
« Reply #9066 on: October 25, 2015, 02:18:55 AM »
When was the race on Krusty? I thought it was later tonight? Poop! Looks like I've missed another one! ;D
Offline Bailgang
  • Scott
  • Indiana
« Reply #9067 on: October 25, 2015, 02:40:15 AM »
My kid told me to watch it saying something very unexpected happened in the race. I have it recorded on my dvr so I'll check it out later.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline petercb750
« Reply #9068 on: October 25, 2015, 03:29:16 AM »
He pisses me off too. He's a fkn prick.
Offline krusty
« Reply #9069 on: October 25, 2015, 03:42:56 AM »
Started about 1800hrs
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline petercb750
« Reply #9070 on: October 25, 2015, 03:57:57 AM »
Mawson lakes?? You're closer to Alice Springs than Adelaide. :o
« Reply #9071 on: October 25, 2015, 04:02:01 AM »
Rossi's a prick? What the fcuk? Who'd he murder? Everyone loves the Doctor! ;D
Offline petercb750
« Reply #9072 on: October 25, 2015, 04:14:54 AM »
I've never liked him and now I know why...prick.
Offline petercb750
« Reply #9073 on: October 25, 2015, 04:33:23 AM »
And pie floaters.
It pisses me off that the pie cart got banned by the council.
Offline Bailgang
  • Scott
  • Indiana
« Reply #9074 on: October 25, 2015, 05:28:21 AM »
I'm trying not to be a spoiler for anyone who hasn't seen the race yet but Rossi may have screwed himself.
Scott
71 cb350 twin
77 cb750 F2
