Good tips here guys.  I'm feeling a bit dense and have used the search function.  Ive pulled the cam and rockers/shafts and see the 12mm stud nuts around the cam towers.  I saw its best remove the 4 small hex head bolts near the spark plugs:
1) The four small phillips/hex head bolts near the spark plugs look impossible to reach by sliding an open ended wrench through the fins(unless I grind the wrench down to about half its thickness.  Any other ideas to remove these? (I haven't tackled it yet, and have to go to work but if there's a trick or tool I can buy at sears then Ill pick it up on the way home)  Grumpy, did you just use a long phillips at an extreme angle? Howd you do it?
2) Here's where I'm feeling extra dense.  The 12mm stud nuts under the cam tower seem barely or not accessible with a 12mm open ended wrench.  A socket doesn't fit because of the shape and overhang of the cam towers.  A closed 12mm wrench is too thick to slip over the stud and clear the edges of the cam tower.  How did you guys pull these without going crazy or stripping the bolts by not getting good wrench to nut contact?  I used a standard 12mm opened ended wrench and was just able to spin the more accessible of the bunch but the ones near the center of the cam towers are very recessed.
Any help would be greatly appreciated.
Not real sure what the problem is here. Maybe its that you haven't removed the cam towers/bearings/stands themselves?  But you say you've removed them?  If you have then this should all be clear. All the fasteners are straight shots, easy peazy. (Remember the 4 under the pucks come off/out first)
But your statement..."overhang of the cam towers" makes it sound like they are still there. They should be completely off the head.
All the things you inquire about are easily solvable, done all the time. First the comb hex/phillips are usually engaged from above. You must remove the rubber quarter size "biscuits" from their holes. If you're lucky a T Handle #3 phillips will get them. But not at an angle its a straight shot down from above. Too tight for that, a thinwalled deep well socket should do the trick.
All the 12mm head nuts should be accessable with standard 12mm socket, again straight shot.
