Author Topic: New Member in Birmingham AL  (Read 623 times)
Offline LoVel
  • Yes, I remember your mother well. She was quite the
  • 1972 CB500 four
« on: July 30, 2012, 08:01:53 AM »
Bought a poorly running 1972 CB500 a couple of years ago.  Have rebuilt the carbs and in an attempt to fix an oil pump that was leaking like a faucet made a little mistake with an O ring which caused a Cam shaft and head problem.
After replacing the cylinder head and cover along with the cam shaft and oil pump the bike is up and running again.  Those engines are heavy.
I have put on new tires(the ones on it were from the 70s), petcock, fuel hoses, rebuilt the carbs, replaced all gasket and Orings above the crankcase, replace the cylinder head, head cover and cam shaft, 4 into 1 exhaust, chain and sprockets, found and reinstalled original footpegs, and relocated the ignition back to original.  The bike had floor boards, a windjammer and highway bars on it when I bought it.
Don't currently have a picture but will take a few soon and get them loaded.  The only current problem with the bike is the idle gets weird after the bike is completely warm. Will go into a rather hi idle 2000rpm plus when coming to a stop.  I can drag it down with the clutch and then it will stay low until the throttle is used again.  Will search around some and see what I can come up with but will probably post a more specific question after I have put more miles and longer trips on her.
I'm an individual,  just like everyone else.
Offline cabrala
  • Super Duper
Re: New Member in Birmingham AL
« Reply #1 on: July 30, 2012, 09:03:43 AM »
Damn straight this place is clicky.  Made my first post in the new memeber thread less than ten minutes ago and no one has bothered to tell me hi.   ;D
HAHA!! Hi Love. Welcome to the the home of the SOHC4 clique.  8)
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
Need a better, newer points cover gasket? How about rubber washers for the headlight bucket? Click the link below:
http://forums.sohc4.net/index.php?topic=122308.0
Offline LoVel
  • 1972 CB500 four
« Reply #2 on: July 30, 2012, 09:16:01 AM »
Thanks crush.  I am glad I found this place. Really enjoying just the little bit of reading I have done so far.
My bike is not a beauty queen but she seems to run well and so far I don't think I have any leaks since the rebuild.
Offline cabrala
  • Super Duper
« Reply #3 on: July 30, 2012, 09:35:01 AM »
Pictures soon or nobody will even believe you own a bike! ;)
Be sure to search like crazy, but don't be afraid to ask for help. We're all in the same boat as you.
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
