Author Topic: Smoke coming out the breather tube from the rocker cover.  (Read 11417 times)
Offline Vincent P
« on: July 30, 2012, 07:28:30 PM »
Just rebuilt the top end of the motor on my 73 CB750.
Cylinder head machined new valves, and valve seals. Have great compression 145 plus on all cylinders. When I had the head off I looked at the cylinders and they is no scoring or bad wear.
Now when I run the motor I get an awful lot of smoke out the breather hose that is at the top of the rocker cover. No smoke out the exhaust though.
Anyone have any ideas what could be happening.
Note: oil level seems fine.
1973 Honda CB750 K3
Re: Smoke coming out the breather tube from the rocker cover.
« Reply #1 on: July 30, 2012, 09:23:10 PM »
Is it smoke, or water vapor? Smoke tends to linger, while vapor dissipates. Any running issues?
Offline Vincent P
« Reply #2 on: July 31, 2012, 03:46:29 AM »
It does not appear to be water vapour.
1973 Honda CB750 K3
Offline Lostboy Steve
« Reply #3 on: July 31, 2012, 05:02:58 AM »
I have the same thing on my 77 cb550k after a complete rebuild. It seems to be getting better after the first 500. We'll see what happens. I routed the breather back into the air filter box and now I don't see it at least.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Vincent P
« Reply #4 on: July 31, 2012, 07:32:42 AM »
I took the breather box off and installed the single cones on the unit, so routing it into the box is out.  ;)
I will run it and see what happens.
Thanks,
VP
1973 Honda CB750 K3
« Reply #5 on: July 31, 2012, 08:13:06 AM »
Yeah I had pods. I made a catch can and put a little uni filter on it and that calmed it down as well.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline lucky
« Reply #6 on: July 31, 2012, 10:00:03 AM »
Make sure the top end is getting oil.
Many on this forum have made mistakes putting engines together not getting the oil seals right.
Does it seem normal otherwise? no noise?
Is it jetted for pods???
Offline Vincent P
« Reply #7 on: July 31, 2012, 11:20:15 AM »
Running normal a far as noise; but not jetted for pods, jetted for the stock air filter box.
1973 Honda CB750 K3
Offline CycleRanger
  • No comment about being an
« Reply #8 on: July 31, 2012, 11:25:10 AM »
What about valve guides?
Offline Vincent P
« Reply #9 on: July 31, 2012, 11:43:39 AM »
Completely redone by a very reputable shop here in town.
1973 Honda CB750 K3
Offline CycleRanger
« Reply #10 on: July 31, 2012, 11:58:21 AM »
The valve guides were replaced with new ones or were the old ones just reamed?
« Reply #11 on: July 31, 2012, 12:07:51 PM »
I'd bet on water vapor too, particularly if it is white.  Dissipation time depends on outside humidity level.  (You got any humidity there is AZ, Scottly?  Is it monsoon season?)
Anyway, get the entire engine and trans unit up to operating temperature and keep it there for 15-20 minutes.  That's a rough guideline to ensure all the water has been vaporized and evaporated.
You may never get the far ends of the trans hot enough to convert all the water, while idling in the shop, or driving it leisurely around the block.  And every time you cool it down, it will pull more humidity from the air and collect it inside the engine/trans.
Offline Vincent P
« Reply #12 on: July 31, 2012, 01:17:33 PM »
It is a pure white smoke come to think of it not a bluish like when you burn oil.
Hmmm, something to try.
1973 Honda CB750 K3
Offline CycleRanger
« Reply #13 on: July 31, 2012, 03:15:04 PM »
Check your oil tank and see if there's some chocolate-milk looking residue on the cap or inside the top of the tank. That's moisture.
Offline Vincent P
« Reply #14 on: July 31, 2012, 05:22:51 PM »
Will give that a look.
1973 Honda CB750 K3
« Reply #15 on: July 31, 2012, 07:37:38 PM »
Valve guides/seals cannot cause blow-by out the breather; they might cause oil smoke out the exhaust. Blow-by is caused by bad ring seal, and it doesn't sound like that is the issue in this case.
Yes Lloyd, the monsoon hit here with a vengeance about 2 weeks ago. I made my weekly grocery run today, and on my last stop parked on a slight incline; when I came out 10 minutes later, there was a small stream of water running from under the car, condensed from the AC. It's not a "dry heat" right now.. :(
