Author Topic: 350f engine assembly question - HELP!!  (Read 914 times)
Offline camelman
  • Man... Myth... Legend
« on: July 31, 2012, 10:46:31 AM »
So, I'm finally getting one of my 350f engines back together and do not have a template engine to compare to.  I'm lost on how to assemble the intermediate shaft that goes through the starter clutch assembly and transfers the power from the crankshaft to the clutch.  I have a 400f and 350f book, but I can't find a clear picture to answer my question.
Here's how I understand it, and how I assembled it:
1) The shaft goes through the block from the oil pump side with no washers or spacers on the oil pump side.  It goes through the starter clutch assembly towards to the clutch assembly.
2) The "hat" spacer goes between the starter clutch and the bearing on the clutch side.
3) After the circlip is in place, the small spacer is installed, then the drive gear and bolt are installed.
Can anyone verify that for me?
Thanks,
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline camelman
Re: 350f engine assembly question - HELP!!
« Reply #1 on: July 31, 2012, 06:47:26 PM »
Ummm, help?
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #2 on: July 31, 2012, 11:57:48 PM »
Yes that is correct.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline camelman
« Reply #3 on: August 01, 2012, 12:26:56 AM »
Kevin, you rock!!  Now, all I have to do us reassemble!!
