The SOHC/4 World Tour is in under way.
That should do it. There's also a plastic cover that goes over the lock assembly. No longer available from Honda. CSMNL may have one.
I think without the cover the lock mechanism can be pulled out or might fall out when it's unlocked.
Now, as it is required in Finland for all bikes after 1974 I'd need to put one back.
Hello,The previous owner (yes, I can still blame him for everything ) removed the steering lock from my K7 as unnecessary ballast. Now, as it is required in Finland for all bikes after 1974 I'd need to put one back.Looking at the vertical tube up front there is a slot that I believe is for the steering lock. What else do I need? Some googling suggested that this would work: http://www.louis.de/index.php?topic=artnr_gr&artnr_gr=10001810&lang=en but would I also need some other parts? To me it seems that there is just a slot in the bike..Thanks,Ville
Bets me, but this is just one of the things that often make me think that Finland is actually a lost Soviet state "Absurdnia".
