Author Topic: allballz problems  (Read 1001 times)
Offline the technological J
  • deliciouso!
allballz problems
« on: August 03, 2012, 08:10:21 AM »
i ordered a set of tapered bearings a while back i finally got around to puting them on the K4 and they  do not fit the outer race on the lower bearing isnt any where near going together the inner diameter on the lower doesnt seem to fit the neck either with out a serious pressing... the top race is just the opposite its slips on and off with ease and seems too thick for the seated area... the part numbers are 32005X- 26 and 32006X
 any suggestions? were they different for the K8?
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline liPPy
  • 1978 cb750k
Re: allballz problems
« Reply #1 on: August 03, 2012, 08:29:55 AM »
Not sure what those part numbers you list reference but this is the bearing kit I used on my '78 750K without problems:
http://www.allballsracing.com/22-1011.html
Offline phil71
« Reply #2 on: August 03, 2012, 08:31:52 AM »
are you trying to jam them into original races?
Offline goldarrow
  • one day, i'll be an
« Reply #3 on: August 03, 2012, 09:12:54 AM »
I think Part numbers for All Balls Steering Stem Bearing Kit 22-1011.
CB550 K0
  • deliciouso!
« Reply #4 on: August 03, 2012, 09:53:11 PM »
The original races have def been removed..il take some pics and post them.. The numbers I listed were listed inside the package....any body know if the neck changed on the k7 or k8?
94 ST1100..Gone
Offline xnoahx
  • 78 750K
« Reply #5 on: August 03, 2012, 10:21:35 PM »
I just put the 22-1011 on my K8.  I did have to pound the lower bearing onto the stem.  To fit the races in the neck I placed them in the freezer to give them a little extra clearance and them put them in the next and drove them home with a block of wood and a drift.  A long piece of PVC pipe like in Lippy's picture helps greatly for getting the lower bearing on the stem
bollingball
« Reply #6 on: August 03, 2012, 10:43:01 PM »
First you say a K4. Then you ask about a K8 What is going on? Do you have a K4 with a K8 neck??
Ken
  • deliciouso!
« Reply #7 on: August 04, 2012, 06:19:34 AM »
 i had a k8 and i dont know if i ordered ones for the k8 or if there was a difference between the  k8s neck or if i got the wrong bearings all around... the bearings are def wrong tho
94 ST1100..Gone
Offline fmctm1sw
« Reply #8 on: August 04, 2012, 06:31:43 AM »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
  • deliciouso!
« Reply #9 on: August 04, 2012, 07:59:35 AM »
 essentially the bottom one is an1/8th of an inch too big and the top is about the same to small and there are no spacers
http://youtu.be/fxaL3WaLwg0
<iframe width="560" height="315" src=" frameborder="0" allowfullscreen></iframe>
94 ST1100..Gone
bollingball
« Reply #10 on: August 04, 2012, 09:28:33 AM »
Try a cross reference for the OEM bearings for 74 and 78 see if they are the same if they are then the allballs should be the same also.
Ken
Offline CycleRanger
  • No comment about being an
« Reply #11 on: August 04, 2012, 09:47:08 AM »
You never said what Allballz kit you are trying to use. If it's a 22-1011 then it has the wrong bearings in the kit.
If it's some other part number you have the wrong kit.
That same kit works for all the 750's.
  • deliciouso!
« Reply #12 on: August 04, 2012, 10:18:26 AM »
i just checked the tag it said 22- 1020.... crapo
 i need to remember where i bought these from
94 ST1100..Gone
