Author Topic: Help me foil this perpetrator  (Read 2771 times)
Offline HonderCB
Re: Help me foil this perpetrator
« Reply #25 on: August 05, 2012, 03:42:00 PM »
he who seeks revenge should dig two graves....
that being said, punch him in the ball sack lol
77' CB750F
81' CB650C - SOLD
Offline Killer Canary
  • Typical Bran Muffin
« Reply #26 on: August 05, 2012, 04:43:11 PM »
Put grease on his wiper blades.
Kawi GPz900, H1
« Reply #27 on: August 05, 2012, 05:16:28 PM »
Put a couple of shrimps in the tool box and see how long it takes him to work out where the smell is coming from.
Thats a good one....  I know a guy that put a box of shrimp in an ex employers air con ducting.....   Stunk the whole place out... ;D
« Reply #28 on: August 05, 2012, 06:21:18 PM »
Put vaseline on his fuse clips/ends
Buy some pink sidewalk chalk and give him a set of pinkwall tires....
Reverse his mirrors so they are pointed to the front.
Apply numerous hearts or other graphics with chapstick on the face of his mirrors.
Get a vinyl sign shop cut you in white or bright yellow vinyl, "diĀ¢-less sits here" printed on two lines and apply it where he would straddle.
Put a sardine in each of his exhaust pipes...once that bakes in it will reek everytime the pipes get hot.
Trap a mouse and put it inside his battery cover atop his battery...also place shredded newspaper and other mouse like nest material in the "nest"  if you want him to worry be certain to include bits or MC wire insulation in the nest near the top so its obvious. You can wash it after chipping and clipping it and then chew on it so it is mangled like a mouse chewed it. No stripped  ends of wire if you want it realistic.
Find a couple screws that look like they would be to his points cover or some greasy/oily 6 mm nuts and tape them on his seat. It will drive him nuts looking for where you took them. Have on of them be to his bike for a cover could lead him to a search expedition.
« Last Edit: August 05, 2012, 06:32:34 PM by RAFster122S »
« Reply #29 on: August 05, 2012, 06:43:50 PM »
I hope I never piss you off, David! :o ;D
« Reply #30 on: August 06, 2012, 02:37:38 AM »
Scottly, your a friend and I would never prank you bikes,
the sardine one is kinda nail in the coffin for a friendship as one that heavy putrid oil burns into the exhaust it is gonna take some harsh measures to eliminate it.
Visual side benefit, all manner of cats will hang around the bike, climbing all over it.
Another simple one would be to pull several vale inspection ports and leave them on the seiat.  He'd have freshly adjusted valves either before he left or shortly afterwards. The ride home would be pucker listening for abnormal sounds.
Offline switchum
    • Studio Switchum facebook page
« Reply #31 on: August 07, 2012, 08:17:07 AM »
  I usually put condoms on grips. You can squirt some lotion inside for more traumatic effect.
Offline Damfino
« Reply #32 on: August 07, 2012, 08:34:58 AM »
I think we scared the OP... ;D
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline DJ_AX
« Reply #33 on: August 07, 2012, 09:13:25 AM »
Put vaseline on his fuse clips/ends.....
That would be just like using Dielectric grease...
