Author Topic: 73 honda 750 has no power under a load  (Read 1459 times)
Offline honda 750
« on: August 06, 2012, 09:02:35 AM »
i just got bike running after 30 yrs in storage    had carbs all redone. bike starts up and has plenty of rpm at idle but when i took in down the road for test run . would only get about 5000 rpm and 55mph  on hiway   there was no top end power. any help will help
Re: 73 honda 750 has no power under a load
« Reply #1 on: August 06, 2012, 09:20:48 AM »
Check the timing and advance mechanism. Do wet rag test to make sure all 4 cylinders are hitting well. Sure others will have lots more suggestions.  What set up are you running as far as pipes,filter etc.
Offline honda 750
« Reply #2 on: August 06, 2012, 09:33:58 AM »
running all stock  filters and pipes     carbs were re jeted to 100
Offline Really?
« Reply #3 on: August 06, 2012, 09:40:13 AM »
I there a reason why your jets are 100?  Altitude?  I think the 75/76 were 105's and prior may have even been 110/115/120.
« Last Edit: August 06, 2012, 01:12:07 PM by Really? »
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Really?
« Reply #4 on: August 06, 2012, 09:44:40 AM »
Offline honda 750
« Reply #5 on: August 06, 2012, 01:11:00 PM »
thanks for the thread
     i rechecked slip on carbs and they are 120 jet
Offline Really?
« Reply #6 on: August 06, 2012, 01:19:14 PM »
A good recommendation, if you have not done it yet, would be to do the 3K tune up that is in the downloadable manual.  It would be good to know what every part needing to be checked is right (i.e. timing chain adjustment, valve adjustment, points/plate adjustment and condition...).
Since you said that the filters and pipes are stock, jetting at what it is supposed to be per the carb model number should be a good place to start.
You can checked for air leaks on the front a rear boots of the carbs too.
« Reply #7 on: August 06, 2012, 01:31:39 PM »
If you are running all stock then 120 are too large for a 73 750 - check your plugs are they all dark and sooty? Drop to 110 or 105s or/and check the stamp on your carbs - 657? Then do a check of which main jets were stock for your carb - I dont recall off hand but Hondaman posted extensively on this so do a quick search. Also verify the main jets/emulsion tubs are actually clean - did you do it yourself or someone do it for you?
I had an issue like yours once and it turned out to be a faulty condensor. But check the fuel pathway first.
Offline honda 750
« Reply #8 on: August 06, 2012, 01:40:11 PM »
i had carbs done by old school carbs
Offline Johnie
« Reply #9 on: August 06, 2012, 01:44:40 PM »
Just to rule it out...by any chance did you do a compressoion check?
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #10 on: August 06, 2012, 02:07:59 PM »
Points ignition?
You sure all cylinders are firing and the header pipes are the same temp?
Offline honda 750
« Reply #11 on: August 07, 2012, 06:06:35 AM »
compression is good on all4 cylinders   130-145     spark on all cylinders    did find #4 cylinder not getting gas  plug is like bran new no sign of firing at all    so i will look at that carb to see what problem is
Offline Old Scrambler
« Reply #12 on: August 07, 2012, 06:16:56 AM »
Is it a new air-filter?
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #13 on: August 07, 2012, 06:27:28 AM »
Might be as simple as the float or needle being stuck or bound up. Wiggle it around a little,put the bowl back on and give it a try. Love those clips instead of screws. By turning on the petcock with the bowl off you can also confirm you are getting a good flow.
« Last Edit: August 07, 2012, 07:21:14 AM by ekpent »
