Wow, ok there is a lot going on there in that video. Did you really take the carbs on and off 10+ times? Each time did you only address the idle jet? You didn't clean the rest of the rack at all, take it apart, address the fuel circuits, anything? Exactly what did you do when you "cleaned" them? Also, are you sure that smoke is coming from the breather hose? Cause it looks like it is coming from the airbox, like the valves are off and it's shooting back through the carbs. Can you comfirm smoke actually coming out the end of the breather hose?
