Author Topic: Marving exhaust fitting to 750F1  (Read 1536 times)
Offline carl101
« on: August 06, 2012, 01:24:16 PM »
Hi, is it possible to remove the 8 exhaust studs from my '76 750 F1 and fit the 4 exhaust stubs from an earlier K series? Are the cylinder heads the same? I,ve been given a Marving system for an earlier model with no fittings,and don,t want to spend £200+ on a full fitting kit if it won,t fit .Any help would be appreciated.Carl.
Offline mcpuffett
Re: Marving exhaust fitting to 750F1
« Reply #1 on: August 06, 2012, 01:39:49 PM »
Hi Carl yes you can take the studs out and fit the stubs only thing you will have to check is the f1 is different to the k series round the back brake pedal area  ;), cheers Mick.
Offline Grabcon
« Reply #2 on: August 06, 2012, 06:56:19 PM »
I believe that when studs and flanges are used there are copper crush washers in the bottom of the exhaust port. You most likely will need to remove those before you seat the stub type in their place.
CB750   1974 - Gone
CB750F 1976 - Gone :(
CB550   1978 - Gone & now back
CB900F 1981 - Gone
ST1100 1991 - Gone
ST1100 2000 - Gone
VFR800 2008 - Gone
ST1300 2008 - Gone
BMW F700GS - Wife's
VFR1200X 2016 - Mine
Offline carl101
« Reply #3 on: August 07, 2012, 11:05:48 AM »
Thanks for your help,fitting kit ordered. Cheers,Carl.
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
« Reply #4 on: August 10, 2012, 10:29:29 AM »
I would be interested in seeing a pic of the Marving fitted to your bike, particularly where it is supported at the back.
Thanks
Offline 1952paul0
Re: Marving exhaust fitting to 400/4 1977
« Reply #5 on: June 01, 2022, 04:12:08 AM »
Anyone got any pics how the Marving exhaust hangers fit to 400/4?
many thanks,
Paul
« Reply #6 on: June 01, 2022, 10:03:52 AM »
 Both styles need the copper washers.
