Author Topic: '70 CB350 Scrambler Throttle questiom  (Read 1600 times)
Offline Woody49
« on: August 06, 2012, 02:39:10 PM »
OK, so this bike runs great and looks good.  My only problem with the bile is the throttle is so HARD to twist.  Are those return springs on the carbs really that strong?  without the springs on them it turns easy.
Any suggestions?
Thanks
Woody
Offline Sniper X
  • Resistance is not futile, it is voltage devided by current.
Re: '70 CB350 Scrambler Throttle questiom
« Reply #1 on: August 06, 2012, 02:41:22 PM »
No, something is binding. It is probably the throttle grip itself...Sooo, I would lube the cables, and lube under the throttle plastic sleve and make sure the grip isn't rubbing on the switch/throttle housing.....Oh, and make sure the cables are routed correctly as in no binding or kinks.
1973 CB350 Four, 1969 CL350 Scrambler (2) 1985 BMW R80RT.
Offline Woody49
« Reply #2 on: August 06, 2012, 02:46:11 PM »
Thanks for the suggestion, but the twist and cable and the "Y" are all good.
It only binds with the carbs hooked up.
Offline Sniper X
« Reply #3 on: August 06, 2012, 03:19:41 PM »
Sounds like something in the linkage is afoul. How hard is it to actuate the carbs linkage without the cable on it>?
Offline Woody49
« Reply #4 on: August 06, 2012, 05:06:58 PM »
Carb linkage is hard but not rough
Offline Woody49
« Reply #5 on: August 07, 2012, 11:32:42 AM »
OK finally got it to work.  Took a half a can of WD40 down the cables but it is great now.
BUT now it only runs on ONE cylinder.  The left cylinder doesn't fire when I sue the throttle only on that side.
Always something...  Going out now to check the lines etc...
