Sweet 550.
Since these carbs are 100% gravity fed, make sure there are no low spots in your fuel lines. It should be all downhill from the gas tap to the carbs. Also make sure you have enough gas in the tank. They tend to run a bit out of the norm when they get low especially if your fuel tap filter has crud in it.
