Author Topic: What is a Wrinkle Tank?  (Read 2274 times)
Offline DaveInTexas
  • 1970 CB750
« on: June 24, 2006, 05:38:40 PM »
What are they referring to?
What years had this?
Is is desirable or not?
Offline keiths
Re: What is a Wrinkle Tank?
« Reply #1 on: June 24, 2006, 08:28:28 PM »
Dave,
I'm sure someone will correct me if I'm wrong but I think a wrinkle tank is the original tank on the 750 sandcast. It was more wrinkled on the underside than the later models.
« Last Edit: June 25, 2006, 12:06:45 PM by keiths »
jsaab2748
« Reply #2 on: June 24, 2006, 09:00:38 PM »
Dave,
I'm sure some will correct me if I'm wrong but I think a wrinkle tank is the original tank on the 750 sandcast. It was more wrinkled on the underside than the later models.
I believe this to be corect due to the way the first tanks were manufactured. The method was
later changed to produce a tank with a smooth surface floor.
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« Reply #3 on: June 24, 2006, 10:15:01 PM »
The wrinkle thanks were in the early K0 run...including the early sandcasts.  At
some point in the K0 run they switched to a different manufacturing technique
that did away with the wrinkles.
The wrinkles can be seen by looking straight down into the filler hole and run
front to back where the metal bends over the frame.  There are other wrinkles
further back on later tanks, but these don't count as a true wrinkle tank.
Because of there limited numbers and their "correctness" for early restorations,
they have become quite pricey.  :o :o
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
rt
« Reply #4 on: June 25, 2006, 03:05:59 AM »
Those tanks are not confined to Hondas. I had a very wrinkly tank on my Yam a couple of years ago after learning an RD250 is no Off-Roader... and that was NOT DISIRABLE Dave....  ;D
Offline Jonesy
  • Shop Rat
« Reply #5 on: June 25, 2006, 05:38:17 PM »
