Author Topic: Leak Proof Classic Fork Seals  (Read 1872 times)
Offline brewsky
« on: August 07, 2012, 04:33:16 PM »
Just replaced the old seals on my 550 K3 with these.
It was too easy....pushed right on with no driver...just finger pressure....something must be wrong????
OEM on left...
Anybody using these?
Lifetime warranty.........
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Re: Leak Proof Classic Fork Seals
« Reply #1 on: August 07, 2012, 05:51:54 PM »
I used them. They lasted two years. I bought a set from Honda 5 years ago. No issues with Honda.
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
« Reply #2 on: August 07, 2012, 07:09:26 PM »
I used them......only got one season out of them. :( Replaced them with OEM.
..........Paul
Offline brewsky
« Reply #3 on: August 08, 2012, 01:44:11 AM »
Well, I'd kind of hoped for a little better service life.
At least the warranty says "as long as you own the bike", instead of "for the life of the seal"
As easy as the install was, probably don't want to do it every year!
Thanks for the replies!
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
« Reply #4 on: August 08, 2012, 02:20:41 AM »
the seals in forks are designed for a shaft to rub up and down in them,ive used equivalent size seals designed for a shaft that spins with no trouble,if they more or less "fell"into the fork leg that sounds a bit wrong?your legs arent corroded out in the seal area?
Offline brewsky
« Reply #5 on: August 08, 2012, 02:32:05 AM »
No, the seal seat areas are in good shape, and there are no wear/scratch marks on the tubes......fingers crossed.....waiting on the dust caps to arrive...hope they will go on without having to re-disassemble!?!?
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
« Reply #6 on: August 08, 2012, 02:42:52 AM »
so they more or less "fell in"easy,maybe some sealant might help them seal?
Offline brewsky
« Reply #7 on: August 08, 2012, 04:21:58 AM »
They didn't exactly "fall in" place, had to be pushed in, but the fit was not as tight as normal seals you have to bang in place with a split ring.
Evidentally that is the way they are supposed to fit, as the instructions say they are to "float" in the seat area, and need at least 0.5mm clearance between the seal and clip, and 3-4mm space is ok.
OF COURSE, I didn't read the directions till I finished installing the first one, and it felt too easy!!
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline brewsky
« Reply #8 on: August 08, 2012, 04:34:20 AM »
Here's the Instruction sheet:
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
