Author Topic: New Video- 1976 CB550 Valve Adjustment  (Read 6315 times)
Offline SocoMoto
« on: August 08, 2012, 06:28:32 AM »
New video on Youtube on how to adjust the valves for a 1976 cb550.... SocoMoto
https://www.youtube.com/watch?v=bLw6Av07wik
Offline SocoMoto
Re: New Video- 1976 CB550 Valve Adjustment
« Reply #1 on: August 08, 2012, 08:03:16 PM »
<iframe width="560" height="315" src=" frameborder="0" allowfullscreen></iframe>
Offline Dimitri13
  • 1974 CB550K
« Reply #2 on: August 08, 2012, 08:07:11 PM »
SocoMoto: 1976 Honda CB550 Valve Adjustment (part 5).m4v
You have to take the "s" off the "https," because for some reason the forum won't preview on a "verified" youtube link.
Offline SocoMoto
« Reply #3 on: August 08, 2012, 08:14:51 PM »
thanks Dimitri... i was trying to figure that out all day!
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #4 on: August 09, 2012, 02:50:10 PM »
I noticed you left something out in all five videos that is very important. I'm shocked and dismayed that a forum member from SOHC4 could ever forget the most basic of motorcycle maintenance! I'm surprised no one else has reprimanded you Socomoto.
Where the hell is the beer?!?  ;D
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Tews19
  • I am no
« Reply #5 on: August 09, 2012, 07:55:29 PM »
I have been following all your videos. I like them very much. Great work and keep them up!
1970 Honda CB750 survivor.
Offline 72_350_FOUR
« Reply #6 on: August 10, 2012, 10:38:46 AM »
Great Video, answered some of my questions, thanks!!
1972 Honda CB350F
Offline goldarrow
  • one day, i'll be an
« Reply #7 on: August 21, 2012, 10:24:38 PM »
excellent videos you've been sharing here.....
though correct me wrong the breather tube should be pointing to the rear of the engine? unless you intentionally point it that way.
thanks for sharing
CB550 K0
« Reply #8 on: August 22, 2012, 12:14:13 AM »
when you tighten the valve cover down be sure to start with the middle four bolts in the breather sink,then work around to the three either side toward the edges,dont pull down on those front forward four next to the tappet covers untill its all going square and closing up,if you look close they arent real sturdy and ive seen a couple of broken ones,nip them down last,youll find even with the tappet adjusters backed fully off some of the rockers will start to compress the valve springs.
« Last Edit: August 22, 2012, 12:16:39 AM by dave500 »
Offline goldarrow
« Reply #9 on: August 22, 2012, 12:30:23 AM »
+1 and that's how I did mine, torque down to spec about 90 lbs/in or 7.5 lbs/ft which is right in the middle range per manual. Then work your way out in similar fashion when you torque down the head nuts
CB550 K0
« Reply #10 on: August 22, 2012, 12:39:29 AM »
i dont torque 6mm bolts only feel them down,you only need to nip them down and a little more,be sure the threads are clean,any friction on bolts this small in soft alloy will result in stripping of the threads,once the engine has been hot and cold twice just check and nip them again,,use new copper washers on those three either side bolts and the two end cap retainer bolts which need two,one top and bottom of the bolt.
Offline SocoMoto
« Reply #11 on: August 22, 2012, 06:51:52 PM »
yeah, your right, the breather tube should be facing to the back.. when i made the video, it was late and i probably had 1 too many beers.  And yes, you should tighten the bolts starting from the inside out, just like how we did the cylinder nuts... and i also did the front bolts last(the ones by the tappet covers)
Offline sxecafe
« Reply #12 on: September 09, 2012, 04:42:59 PM »
hey.. watched the video. thanks for posting. it's very informative.
Im having an issue as my vales arent opening as both the clyber manual and your video/manual say they should. I cant get both valves on 1 or 4 open at the same tiem. I took off the valve cover and made sure I was set up correctly but that wasnt an issue. The groove was set to be level with the cylinder head at TDC 1-4. Anyone else experience this?
« Reply #13 on: September 10, 2012, 12:59:11 AM »
you want the valves closed at the same time to adjust them,forget the manuals do it like this,for any cylinder,,rotate the engine by hand and watch as the inlet valve goes down,keep turning and watch as it comes up,once it stops coming up its closed fully even though your still turning the engine over,,now look at your timing mark and bring the tdc mark for that cylinder to its index line,do it slow and smoothly with the plugs out it wont be far away,this is where its compressing and both valves are closed,adjust and set this pair of tappets.
Offline sxecafe
« Reply #14 on: September 17, 2012, 05:25:43 PM »
I had the cam chain on incorrectly. Once I lined up TDC on the crank and the cam shaft, all was good. Simple error on reassembly cost me the whole day.
« Reply #15 on: September 18, 2012, 01:01:01 AM »
lucky it didnt cost you bent valves,check and rotate any cam install gently by hand over a few times,then check it again,,rotate it all 720 degrees and do that last check.
Offline sxecafe
« Reply #16 on: October 03, 2012, 10:12:37 AM »
I actually did end up bending the valves. Found that out this weekend when I went to start it for the first time and have ZERO vacuum or compression. Found a head at the local salvage yard and was able to clean it up and install. Very expensive and stupid lesson learned. Def wont be doing that again.
Offline mono
  • Definitely no
« Reply #17 on: October 03, 2012, 07:53:53 PM »
Fantastic video.  I have been putting this off but now i have no excuses !
Sent from my SPH-L710 using Tapatalk 2
