Author Topic: Finished my seat mold  (Read 3304 times)
Offline SHORTROUND
« on: August 09, 2012, 06:40:00 AM »
Finished my seat mold. Time for resin and cloth........and a Beer 8)
Re: Finished my seat mold
« Reply #1 on: August 09, 2012, 09:03:39 AM »
That looks great!
Offline afkrejci90
« Reply #2 on: August 09, 2012, 11:09:01 AM »
What did you make that out of, foam blocks and sanding?
'78 CB750K http://forums.sohc4.net/index.php?topic=105327.0
'80 CB750C - Sold
'06 CBR600RR
Offline knowsnothing
« Reply #3 on: August 09, 2012, 11:51:01 AM »
+1 Would be very interested in the materials and process.
1978 CB750k Blue - for sale
Offline SHORTROUND
« Reply #4 on: August 10, 2012, 05:47:58 AM »
The flat base is blue insulation foam; cut then final shape with a disk sander to keep the edge perpendicular. The hump is green florist foam. You can use the blue foam for the entire seat but the green is easier/faster to cut and sand. The rolled eddge is a piece of 1/2" OD tubing. It helps hide the edge of the seat pan and give it smooth line.
Heres a photo of the finished product from my cb450 made the same way.
The mold made with only blue foam. You don't need the rolled edge if you're gonna snap on the cover.
finished seat
« Reply #5 on: August 10, 2012, 07:28:21 AM »
Awesome, thanks for the info!  Both of the other seats came out great.  Is the blue stuff in the top picture some special tape for the glass to help release it?  And are the molds destroyed after each use?  (Last questions promise)
Offline afkrejci90
« Reply #6 on: August 10, 2012, 10:32:55 AM »
I've started making my own seat but with the pink insulation foam board, it takes forever to sand.  I bet the floral foam is probably the better option.  After you fiberglass the mold, do you use body filler to make a smooth surface to paint?
'80 CB750C - Sold
'06 CBR600RR
Offline SHORTROUND
« Reply #7 on: August 11, 2012, 05:46:12 AM »
It's 3M blue tape. the molds are destroyed after each use, But you can reuse the 1/2" tubing.
Offline SHORTROUND
« Reply #8 on: August 11, 2012, 05:49:07 AM »
Body filler is used to smooth out the surface. the floral foam is much easier to shape but you have to make the seat immediatly. The foam shrinks a little after you sand it.
