Author Topic: Don't need my front fender do I? Tire won't fit it.  (Read 8925 times)
Offline Lostboy Steve
Re: Don't need my front fender do I? Tire won't fit it.
« Reply #25 on: August 10, 2012, 11:49:25 AM »
Dunno what bike you are referring to (add it to your sig) but I wonder why that size tire is rubbing the fender.  I have a 110/90-19 up front on the '75 and it fits, close but it fits.  I may have seen that rub on one ride but still not really sure if it did.
I'm running the same, No rubbing and NO ADVERSE HANDLING. Cuz the next topic will be why not to run a larger front tire which will also be like beating a dead horse.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Mingo
« Reply #26 on: August 10, 2012, 12:20:17 PM »
it rubs on the brake disk side. And also at the front of the fender's underside, where the bolts hold the fender to the bracing.
I haven't had a chance to refit the fender and pull  (bend) it up a bit. I'll do that tomorrow.
Offline Really?
« Reply #27 on: August 10, 2012, 03:01:36 PM »
This is on a 750.  What model bike do you have.  If it is a 750, that 100/90-19 should have no problems.
This is the side where it is the closest.
Brake side has plenty of room.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline 74750k4
« Reply #28 on: August 10, 2012, 03:31:21 PM »
Tried to fit a fender over my 110/90/19, had no luck yet. Maybe slot the attachment holes. How do you stop that bike?:)  Is that a 71' by chance? are those later forks, or just later seal cap trim pieces?
Offline Really?
« Reply #29 on: August 10, 2012, 03:34:30 PM »
it is a '75.  Stops as you would expect it to.  Just fork seal caps from CycleX when I got the shorter tubes.
Offline Mingo
« Reply #30 on: August 10, 2012, 04:00:01 PM »
Okay, after so many told me that it would definitely fit, I went out and tried it again. the left side--the side with the disk--rubs. No way it's going to work.
I then took the fender back off and bent it silly and tried to reinstall. Still not fitting.
I shot some high quality images of the tire rubbing the fender's left side, but the files were too big to upload. I'll try to upload what I can.
Also, the fender seems to have been cut in the past--where it clears the brake assembly. You'll see it in the photos if I can upload them.
Finally, I'm including some shots of my front wheel. Is there any possibility I'm missing a spacer? I don't know.
Offline Mingo
« Reply #31 on: August 10, 2012, 04:00:43 PM »
Another photo.
Offline Mingo
« Reply #32 on: August 10, 2012, 04:01:54 PM »
Another photo--can't fit them all on one post.
Offline Mingo
« Reply #33 on: August 10, 2012, 04:02:21 PM »
Offline Really?
« Reply #34 on: August 10, 2012, 04:17:56 PM »
My fork brace looks different from yours, I think.
You can upload your photo's to something like Photobucket.com and then link them like I do.
Offline Tews19
  • I am no
« Reply #35 on: August 10, 2012, 04:23:53 PM »
Dumb question but if you are facing the bike head on with fender on. Did you remove the left side bolts that hold the fender on? You may need to do this then place you wheel on. Then place the two bolts back on.
1970 Honda CB750 survivor.
Offline Mingo
« Reply #36 on: August 10, 2012, 05:39:41 PM »
Sorry, I don't follow. Are saying wait until the wheel is on the bike to attach the fender, or at least the bolts (opposite the brake side) that hold the fender on? Why?
Offline Tews19
  • I am no
« Reply #37 on: August 10, 2012, 05:47:53 PM »
Make sure the caliper is off. You can have that side all mounted though including fender mounts. Opposite side, rather then putting the two bolts that mount this side to the fork leave off. Side tire in. Mount tire properly. Then you can put the two bolts back on for the fender/fork mount. Then put the caliper on. If you want I can take pics of the specifics if need be. I had the same issue with my K1. Did the above and she mounted fine.
Online scottly
« Reply #38 on: August 10, 2012, 05:51:44 PM »
Mingo, once again, what model bike do you have?? That doesn't look like a late 750 brace at all.
Offline Mingo
« Reply #39 on: August 10, 2012, 05:54:51 PM »
Yeah. Pictures would be great. The caliper is off, but the caliper holding thing is still on there. It has to be, right, as the fender mounts go outside (inside in reference to the bike) the caliper holding thing.
Note, the fender is hard to squeeze into the forks. it's exerting force on both forks even before I put any bolts in.
Offline Mingo
« Reply #40 on: August 10, 2012, 05:57:20 PM »
Sorry, Scottly, it's a 1978 cb750K.
I wonder, however, if my fender was swapped out at some point. Not that I know what it should look like, it just seems weird that I can't get it to work with the tire.
Here's what it looked like the day i got it-- a week ago.
Offline Tews19
  • I am no
« Reply #41 on: August 10, 2012, 06:01:07 PM »
Hard to tell, can you take a pic of the fork lower.
Online scottly
« Reply #42 on: August 10, 2012, 06:15:29 PM »
Yeah, I think a PO put a different fender on it. I may have a pic of a K7 750 brace somewhere. I'll go look...
Offline Mingo
« Reply #43 on: August 10, 2012, 06:17:40 PM »
Here's some more pics of the tire rubbing:
http://photobucket.com/fenderproblems
Online scottly
« Reply #44 on: August 10, 2012, 06:34:53 PM »
I can't find a pic of the K7 brace, but your pic looks nothing like it. That brace makes the late model fender brace look stout, by comparison.  ;) I'll try to post a pic tomorrow...
Offline Mingo
« Reply #45 on: August 10, 2012, 09:31:52 PM »
Thanks to everyone who posted here. After an extensive google image search, it turns out I don't have the original fender on the bike.  In fact, the one I have has been cut up a bit where it meets the brake on the lest fork.
So I've bid on one on eBay and we'll see how that goes.
Thanks again.
Online scottly
« Reply #46 on: August 10, 2012, 09:34:58 PM »
You're welcome. 8)
Offline Really?
« Reply #47 on: August 10, 2012, 09:37:49 PM »
+1
Offline Tews19
  • I am no
« Reply #48 on: August 10, 2012, 10:41:04 PM »
I'm pretty sure I have one laying around here. Needs to be cleaned up but it will work for your bike. PM me if interested.
« Reply #49 on: August 11, 2012, 08:00:53 AM »
He needs one for a K7-8.
Really - your K5 looks so good in Blue! We need to talk Momma into painting...
