Author Topic: Crankshaft bearings and grease  (Read 1299 times)
Offline jollygreengiant
« on: August 12, 2012, 06:49:40 PM »
Hi
I'm doing a complete restoration of a 1977 CB 750 K7, and I'm at a point where I'm putting together crankshaft, countershaft, chains etc and, in a day or two, reassembling the crankcase halves. From what I understand when reading the manual, I'm supposed to apply a thin coating of molybdenum disulfide grease to the crankshaft bearings. Are they not fed with oil? Strangely enough it also looks from the illustrations as if the grease is supposed to be applied to the bearings' backsides. Might this be just to alleviate installation of new bearings? Anyone have an explanation?
Tor, Norway
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
Re: Crankshaft bearings and grease
« Reply #1 on: August 12, 2012, 08:02:13 PM »
The application of assembly lube is necessary to prevent metal contact upon startup before adequate lubrication is supplied.
« Reply #2 on: August 12, 2012, 08:50:12 PM »
I wouldn't grease the backsides. Can't believe that is in a manual. If so it may be a motorcycle only thing. Anyone else ever do that? I would buy an engine assembly lube, there are some very good ones available.
« Reply #3 on: August 13, 2012, 12:40:07 AM »
the backside must be clean and dry.
Offline trueblue
« Reply #4 on: August 13, 2012, 03:06:57 AM »
But what about the bearing ???
1979 CB650Z
« Reply #5 on: August 13, 2012, 06:56:27 AM »
Thanks for all responses, that cleared things up  :D Now, back to work!  ;D
« Reply #6 on: August 13, 2012, 12:51:19 PM »
caution when farting!
« Reply #7 on: August 13, 2012, 01:00:01 PM »
Never trust a fart. So to sum it up, assembly lube on the crank and bearing, back side dry.
