Author Topic: Scrambler Sidepipe Heatshield Rattle Vibration Dampening?  (Read 868 times)
Offline zwish
« on: August 13, 2012, 06:21:35 AM »
I have a '74 CL125 and the heat shield over the header and muffler rattles a good deal when the revs are high.  This is due to a gap (5mm or so) at the little bracket where the shield mounts to the header.  Is it ok to put some rubber in there as a shim?  I'm worried that rubber would melt due to the heat.  Anyways, just curious if there is something that you're supposed to use.  Thanks.
« Last Edit: August 13, 2012, 08:06:42 AM by zwish »
