Author Topic: End of the line(plug wire): Stock or Aftermarket coils on '78 CB750K?  (Read 1052 times)
Offline Kev Nemo
  • Honda Hacker
  • http://fallingapartart.com/
    • FallingApartArt
The middle plug wires have reached their cut-down limit, so it's time to switch the coils (and boots?). I'm trying to decide on stock or something aftermarket. Do either run better with an electronic ignition system (already in place)? Also a link to a good parts source would be appreciated.
Thanks ahead of time!
Destroyed by Design since 2009 http://fallingapartart.com/
- '78 CB750k bobtrack
Offline eldar
Re: End of the line(plug wire): Stock or Aftermarket coils on '78 CB750K?
« Reply #1 on: August 13, 2012, 07:45:57 AM »
Well you could splice in new wires and there is a faq on that but I prefer new coils.
With points, to keep down on maintenance, stick with 5 ohm coils. They do not need to be oem though. Any dual wire 5 ohm will do fine.
If you have an electronic, check its ohm rating but you may be able to go with 3 ohm coils such as those on the later cb750 dohc or the cb900. Those have replaceable wires.
Offline kingcab41
« Reply #2 on: August 13, 2012, 07:54:43 AM »
After pricing a Honda coil, I went with the Pamco Ultimate with coils with replaceable wires. Check cb750supply. The coil #s are in the content list so probably available separately. Very nice people to deal with.
Offline Eydugstr
« Reply #3 on: August 13, 2012, 08:08:06 AM »
Would definitely recommend dyna coils, 5 ohm.  They're smaller than the stock coils and free up a little space for wiring.
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #4 on: August 13, 2012, 10:28:50 AM »
+1 on Dyna coils. Excellent product, and stick with the 5 ohm setup.
Offline Kev Nemo
  • Honda Hacker
    • FallingApartArt
« Reply #6 on: August 14, 2012, 02:04:44 AM »
Pamco Ultimate contains everything for not that much $$$$. As separate part cost much more.
My Ultimate is still in the box waiting..... My bike is still under taking apart...
Offline Kev Nemo
  • Honda Hacker
    • FallingApartArt
« Reply #7 on: August 14, 2012, 09:05:48 AM »
I already have the electronic ignition- I just need the coils/wires. Does someone have a link to the 5ohm Dyna coils and wires?
Offline Kev Nemo
  • Honda Hacker
    • FallingApartArt
« Reply #8 on: August 15, 2012, 08:23:09 AM »
Okay-found a link to the coils: http://www.motorcycle-superstore.com/3/13/123/27907/ITEM/Dynatek-5-ohm-Coil.aspx
Next question- angled output or straight? I'm guessing angled would be the way to go since they're aimed toward the front. I need to figure out the wires, too
