Author Topic: Wintergreen plus unobtainium cam tensioner??  (Read 1134 times)
Offline danfr
    • Apollo Motorcycles
« on: August 14, 2012, 05:40:49 PM »
Ok, we all know that wintergreen does wonders for hardened intake boots. I've also heard that it may work for soaking the rubber velocity stacks to soften them up.
So....what about the rubber on a cam chain tensioner? I am about to slap together my CB350F top end and I was thinking about soaking the tensioner in some wintergreen. The tensioners are pretty hard to find in new condition so it would be great just to recondition what I have?
thoughts??
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
Offline lucky
Re: Wintergreen plus unobtainium cam tensioner??
« Reply #1 on: August 14, 2012, 05:45:40 PM »
The problem with 29+ year old tensioners is they start coming apart and leaving bits of rubber in the oil.
If you soften them up maybe they will just come apart faster.
Get a new tensioner.
"Slap together "... Better be carefully put together with the right stuff.
The 400F tensioner would be the same part, even if it has a different number.
See if these people wil make one for you
http://www.ebay.com/itm/SPROCKET-CB350-CL350-CAM-CHAIN-TENSIONER-SPROCKET-PA6G-polyamide-CNC-/251113247387?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D1331985580617484928%26pid%3D100033%26prg%3D1011%26rk%3D1%26
« Last Edit: August 14, 2012, 05:51:49 PM by lucky »
« Reply #2 on: August 14, 2012, 05:56:33 PM »
Is the tensioner shoe really rubber?  I thought it was a hardened plastic polymer.
I question that the same treatments are applicable to different polymer structures.
You could be the guinea pig, though.  Do let us know if the shoe turns to liquid goo, ok?   ;D
Offline DustyRags
  • I'm not skilled, I'm just a
  • Just try it and see what happens
« Reply #3 on: August 14, 2012, 06:32:24 PM »
From what I've read recently they're spring steel with a vulcanized rubber "belly" and teflon coating.
Now where on earth did I read that...?
1976 CB550K- sold
2005 Kawasaki Vulcan 500- sold
2000 CB750 Nighthawk - sold
1975 XL350 - crashed
2004 Suzuki Vstrom 650 - sold
Offline danfr
« Reply #4 on: August 14, 2012, 11:35:08 PM »
Hmmm sounds like not the best option. I've already had one 750 velocity stack turn to goo, Lord knows what would become of that tensioner!
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
