Author Topic: 100 miles after top end rebuild, need valve adjustment?  (Read 1147 times)
Offline killersoundz
« on: August 16, 2012, 09:28:13 PM »
I've put about a 100 miles on my 750k4 since rebuilding the top end. It's been mixed cruising and some aggressive riding. I replaced the valve tappet screws on the rockers since the old ones were worn out. I adjusted the valve lash right to spec, I double and even triple checked it. It sounded like butter very quiet valves but they are starting to get a little nosier, is it standard procedure to need another valve adjustment after a rebuild?
My project thread:
http://forums.sohc4.net/index.php?topic=107447.0
My CB750K4 Starting up for the first time after a seized motor and rebuild!
Re: 100 miles after top end rebuild, need valve adjustment?
« Reply #1 on: August 16, 2012, 11:38:50 PM »
yep and cam chain adjustment.
Offline lucky
« Reply #2 on: August 17, 2012, 10:00:31 AM »
Yes that is normal.
As the gaskets heat up and crush there is some slight movement.
If it is possible it is good to recheck the torque on the cylinder head studs in the proper order also.
These are normal procedures after an engine rebuild.
If you had a manual it even tells you.
« Reply #3 on: August 17, 2012, 10:14:23 AM »
Yes that is normal.
LOL.
Yeah there's no way to check the head stud nuts. Dang 750's with their no way to take valve cover off
My project thread:
Offline tlbranth
« Reply #4 on: August 17, 2012, 10:14:44 AM »
Seems to me that the cam and the rockers stay the same relative to each other on an OHC engine. On a pushrod engine the gap will close up as the head gasket compresses. Not so with OHC. However, with new screws, I'll bet they hammer down a bit, opening the gap.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
