Author Topic: HELP 76 dt125 throttle problem  (Read 1201 times)
Offline browneematt
  • brownee
« on: August 17, 2012, 07:38:24 AM »
When I roll slowly on the throttle it's fine but if I crank on it it kills the engine. Any help is greatly appreciated
Offline Flying J
Re: HELP 76 dt125 throttle problem
« Reply #1 on: August 17, 2012, 08:04:37 AM »
When did this problem start? Is it a bike you just got running or have you been riding it for a while and then the problem just started? A little back story would help. You are having a carb issue might need to clean them or adjust the idle mixture.
Offline krusty
« Reply #2 on: August 18, 2012, 12:27:01 AM »
Sounds like a fuel problem. Do you have a shop manual? If so check the problem solving page if it has one. Also check that the carb is perfectly clean internally and all jets are clear. Needle jet clip should be in centre position and air screw adjusted out 1.25 turns.
Like previous post mentioned, a little history helps. Is it still running the oil pump or has it been converted to premix?
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline browneematt
  • brownee
« Reply #3 on: August 23, 2012, 06:39:31 AM »
This has been a problem since I got the bike , I just got it running a few days after I got it. Took the carb off and looked inside and it looked great so I didnt really mess with it. I bet I just really need to clean them.
Offline krusty
« Reply #4 on: August 23, 2012, 07:35:22 PM »
It may be the main jet. If it is too big it can allow too much fuel too soon and the result is the engine bogging down or even stalling. Main jet should be between #150 and #180 (according to my 6/75 parts list). Try a smaller size e.g. if it has a #180 try a #170. Does it have the correct plug - B8ES, is it new? Is it running the oil pump, if not jetting may need adjusting (if so this has the effect of leaning out your fuel mixture which is the opposite of what could be occuring but it's still something to consider).
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
