Author Topic: Yes...it will go in 180 out....!  (Read 1251 times)
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« on: June 26, 2006, 07:11:09 PM »
Well....
after trying for ten minutes to fire up the Sandcast engine with only
occasional backfires for success I decided to "recheck" the timing.  I
statically set it when putting the engine back together.
Come to find out that the cam that activates the points can be
installed 180 out so I was closing the points rather than opening
them at TDC.  :o  Reversing the cam resulted in the engine starting
although with lots of help from the choke so something is still not
quite right.......but it runs so I am happy for today.  ;D
....I guess this is better then finding out that the camshaft was put in 180
out.  ;D
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline Bodi
Re: Yes...it will go in 180 out....!
« Reply #1 on: June 26, 2006, 07:26:47 PM »
out.
There's really no "180 out" on the cam... if you set it 180 out - timing mark straight down instead of straight up - one turn of the crank will get you back to 1-4 TDC and voila! the cam is the "right way up".
Offline techy5025
« Reply #2 on: June 26, 2006, 07:30:58 PM »
I guess in that case reversing the points cam would fix it. Two
wrongs make a right??   ;D  The next owner would be in
for a shock though.  :o
Jim
2003 CBR600F4I
« Reply #3 on: June 27, 2006, 03:50:03 AM »
Just plug the blue into the yellow wire, and vice versa. ;D
