Author Topic: Jockey Shift  (Read 8072 times)
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: Jockey Shift
« Reply #25 on: July 04, 2006, 05:07:15 PM »
Here are the pics
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline Uncle Ernie
Re: Jockey Shift
« Reply #26 on: July 04, 2006, 07:03:17 PM »
Bill, you should know this by now; "suicide shift" is occasionally substuted for "jockey" shift. Usually by folks who have only looked at pictures.  A jockey shift goes straight to the tranny. A hand shift has linkage in order to more conveniently locate the shifter (usually the side of the tank).  Indian is usually referred to as a handshift, while HD is referred to as a gateshift because it has indents in a chrome bar looking thing (a gate) on the side of the tank.  Indian uses DEtents in the engine and is somewhat less precise, but quicker to shift once you get the hang of it.  Both stock bikes employ a foot clutch that stays where you put it by the use of a friction plate.
A "suicide clutch" is so named because it is spring-loaded, sort of like a car.  They are usually used in an after-market situation in conjuction with what is often called a mouse trap- linkage set-up to convert a normal bike to suicide clutch and hand shift.  (HDs and Indian 45s use a suicide clutch for racing applications, however, becaue it's a faster shift).  Anyhoo- the suicide clutch is so named because with one foot on the spring loaded clutch, you only have one foot to put on the ground at stops. It can be very uncomfortable, inconvenient, or even dangerous if your passenger moves, and making a left turn from a stop can be difficult.
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
Re: Jockey Shift
« Reply #27 on: July 04, 2006, 07:50:01 PM »
                     Yeah, I gotcha, I knew about the suicide clutch. I should have known that someone just
        threw the term "suicide" on the shifter. I heard it said, previously, that it could be suicide taking
        your hand off the handlebars to shift and I thought about back when that's all they had was a
        hand shift (or whatever). Personally, if I was to put a hand shift on a bike now days, I think I'd
        come up a little and then curve it toward the front of the bike and have it almost parallel with the
        road (but, not quite parallel) and put the clutch lever on it in the same position as if it were on the
        handlebar and with a handle bar grip on it. Know what I mean? Catch you later.      Bill
Member # 1969
Offline Uncle Ernie
Re: Jockey Shift
« Reply #28 on: July 04, 2006, 08:03:17 PM »
There's a guy here in town who did that. I forgot what brand it is, but it's gorgeous. He put a polished dirt bike lever for the clutch on the shift lever. It's pretty inconvenient-looking in use, but it looks cool when it's parked  ::)
Offline bill440cars
Re: Jockey Shift
« Reply #29 on: July 06, 2006, 10:50:45 PM »
                   That setup might be allright for some but, I can't see me wanting to do that to my bikes.
         At least not the ones I have now.  Later on, Bill
Member # 1969
