Author Topic: 1971 honda cb 750 project / Update problem changing oil  (Read 93821 times)
Offline Tews19
  • I am no
Re: 1971 honda cb 750 project / Update 1/16/2013... on the ground again
« Reply #150 on: January 17, 2013, 03:22:09 PM »
Gary! I got an ignition and key from my silver k1. Pm if interested
1970 Honda CB750 survivor.
Offline Kevin D
  • SE Michigan
« Reply #151 on: January 17, 2013, 05:50:01 PM »
Gently unfold the tabs on the back of the switch, don't lose the little spring loaded parts, clean out the old grease, clean the copper parts with scotchbrite, reassemble.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Tews19
  • I am no
« Reply #152 on: January 17, 2013, 05:52:14 PM »
Also make sure the male end fits properly to the female end. Sone times the male ends get bent
Offline Kevin D
  • SE Michigan
« Reply #153 on: January 17, 2013, 06:05:12 PM »
Also make sure the male end fits properly to the female end. Some times the male ends get bent
+1..... I forgot that one ::).... one of the pins was wobbly and got pushed out the back of the harness connector.
I ended up with a new switch as the pins in the lock were worn out and fell apart. I was able to make the old switch work but I was afraid to lose my keys out on the road.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
Offline Garystratos201
  • I have never been a
« Reply #154 on: January 18, 2013, 07:15:43 AM »
Its definatley not a loose connection. I could press on the backside of the switch and make it work for awhile. But as I checked out the different systems turning the switch on and off quite a few times it finally quit working all together........Gary
Tews pm sent
Visit my build project;
http://forums.sohc4.net/index.php?topic=111620.0
Current ride; Bass boat.... 2005 Ranger 521VX,250 hp Mercury Verado, super charged and direct fuel injected. Not a bass on the lake can out run me !!!
« Reply #155 on: January 19, 2013, 01:30:39 PM »
Well I tried cleaning the switch but it didnt help but I did manage to take apart the starter solenoid and clean it now the starter works fine. Monday I`ll put on the oil lines and oil tank. I`m hoping the carburetor boots will be pliable enough to reuse if they are then on go the carburetors and I`ll try and get it to start.........Gary
Offline Tews19
  • I am no
« Reply #156 on: January 19, 2013, 04:33:03 PM »
Wintergreen soaking will soften all rubber. Pics have been sent Gary.
Offline cheftuskey121
  • Super Newbie
« Reply #157 on: January 19, 2013, 05:46:38 PM »
so excited for you Gary! can't wait to hear it running
« Reply #158 on: February 01, 2013, 02:21:49 PM »
I havent posted an update in awhile mainly because I had gotten so frustrated I had to walk away from it for awhile. The dreaded hardened carb boots......I know, I  know you can heat them up with wintergreen oil and water for several hours and they will soften up. Its very true they did and after two hours of wrestling with them I got them on but they dont want to stay on and the fit didnt suit me. So I moved on the the air intake boots and after another two hours of frustration I gave up and ordered new boots for both the airbox and the intake manifold. They are supposed to be here Monday. Hopefully that will make them go together much easier. I did get my speedo, tach and switch ( Thanks Tews your a great guy ) Installed  them with brand new shiny mounting rings and mounting hardware. Did I mention I love shiny new stuff? All my electrical is now working and getting very close to trying to start her up. I apologize for the quality of the photos but it was very cold and I couldnt open the garage door so the lighting was very poor.
« Last Edit: February 02, 2013, 09:10:21 AM by Garystratos201 »
Offline Prospect
« Reply #159 on: February 01, 2013, 06:42:23 PM »
You'll appreciate the tight seal new rubber creates when you synch the carbs.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline jerry h
« Reply #160 on: February 01, 2013, 10:08:00 PM »
Was the problem the boots were too hard yet, or was it everything wasn't aligning up?
   Excellent !   Forward progress ;D
Lookin good!
« Reply #161 on: February 02, 2013, 08:48:37 AM »
The carb boots softened up ok but they became a little out of shape when I boiled them. Who knows maybe I got them to hot. The air intake boots were rock hard and i couldnt do anything with them aggravation got the best of me and i gave up and ordered new. It seems like this bike is fighting me at everything I try to do. But I will win in the end..........Gary
Re: 1971 honda cb 750 project / Update 2/4/2013... Success carbs on!!!
« Reply #162 on: February 04, 2013, 12:19:58 PM »
Got my new air box boots and carb boots from Service Honda today. Man I couldnt believe the difference my old ones were as hard as a rock. Seriously from start to finish it only took about an hour to put the carbs and top half of the air box on. That includes taking the carbs back off and removing all the old clamps. I cant believe I spent well over 5 hours wrestling with the old boots. My new fuel line should be here soon and then it will be time to try and start her up. I`m excited !!! Any tips or hints on the initial start up ? Thanks guys for all your help, this forum is great..........Gary
  • Super Newbie
« Reply #163 on: February 04, 2013, 01:29:34 PM »
so awesome Gary, night and day from the old rubber. glad you got the new boots. I remember still not being satisfied with the snugness/fitment of the airbox boots though and I got new ones. it had to do with the angledness of the airbox boots. of course I never checked if it WAS leaking by spraying anything, I was just too excited to actually get it started. I;m sure when I get things buttoned back up and fit them on again I'll encounter the same issue but hopefully can get a resolve. keep it up man, can't wait to see that thing fire. MAKE SURE YOU take video and post it!
« Reply #164 on: February 06, 2013, 08:20:43 AM »
Well here we go again..........Point gap is right static timing is right but i only get it to  fire occasionally on one or two cylinders. I can put my hand over the intake of the carb and turn it over and get fuel sucked out on all but number one cylinder, Iwas hoping to get by without rebuilding my carbs but now I`m not so sure. I havent gave up but my tournament season starts in about three weeks and thats gonna cut into my time but much more into my cash...........gary
Offline edhaeuser
« Reply #165 on: February 06, 2013, 10:05:03 AM »
Did you try a shot of starting fluid in each in the carb intakes  and then try to start?  That should tell for sure if you have a fuel supply/carb problem.
Ed
« Reply #166 on: February 06, 2013, 11:40:45 AM »
Ed
No but I will. Thanks for the advice........Gary
Offline Johnie
« Reply #167 on: February 06, 2013, 02:04:03 PM »
The carbs are the heart and soul of a great running bike. Don't cut corners and git 'er done. You will be glad you did. Not really a difficult job at all. Especially with the help from this board. Good luck and let us know how you come out.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #168 on: February 07, 2013, 11:19:15 AM »
Well I can make her run, but only with the choke pulled all the way. Dang I forgot how good they sound!!! Definitely gonna have to rebuilld the carbs. I`m not comfortable doing it myself so they will be off to SOHCdigger early next week. Found a nasty oil leak in one of the oil lines that will have to be replaced. Also have ordered new dust boots for the carbs from Service Honda. Man I`ve still got a long list of things I need. Throttle cables, Speedo and tach cables, Rear wheel bearings, brake shoes and maybe the dampers. I did manage to get a good deal on some high density foam from a local upholstery shop $3.00 also the guy gave me directions on how to cut and shaoe the foam. So I`ll have enough to keep me busy until my carbs come back. Bass tournament in 10 days be nice to win and take the prize money to fund my project........Gary
Offline Tews19
  • I am no
Re: 1971 honda cb 750 project / Update 2/7/2013... She runs!!!
« Reply #169 on: February 07, 2013, 11:58:21 AM »
I saw bass boat in your sig. You fish for big money? Will we see you on the new fishing reality show in the future?
« Reply #170 on: February 07, 2013, 12:12:29 PM »
I did fish The BFL circuit which is part of the FLW trail but unfortunately when I retired I had to give up the Pro tournaments. I have fished for the big money and won some decent money. But now i just fish some local tournaments and club tournaments. I`m not familiar with the reality show your talking about....Gary
« Reply #171 on: February 07, 2013, 01:45:19 PM »
I went out to the garage and made a short video of her running. Man its a great thing to hear her finally coming back to life..........Gary
750 finally runs
« Last Edit: February 07, 2013, 02:12:30 PM by Garystratos201 »
  • Super Newbie
Re: 1971 honda cb 750 project / Update 2/7/2013... She runs!!! short video
« Reply #172 on: February 07, 2013, 08:28:07 PM »
very awesome gary! that thing sounds MEAN! so jealous man all this mucking around I am doing and now I am at a crossroads with the engine. I think I am going to opt out of going through it and take my chances and maybe in a year when it breaks down I'll have no choice but to go through it. I'm starting to itch to have it finished. on the plus side my paint is on the way so tomorrow will be spent stripping the tank and prepping all things to be painted.
can't wait to see the rest of yours come together!
Offline iron_worker
« Reply #173 on: February 08, 2013, 07:59:55 AM »
Man I think you just gave me spring fever. lol
IW
« Reply #174 on: February 08, 2013, 08:07:08 AM »
Thanks guys. I`ve still got some things to do before its ready to ride but just to hear her breathe again was like Christmas to a ten year old................Gary
