Author Topic: Project: Can't Get Right.  (Read 10665 times)
Offline bjonesin
    • My Project
« on: August 19, 2012, 03:01:28 PM »
Hello to the Forum! In early February I purchased a 1977 CB750. I've never had a motorcycle, nor really any idea of what I was getting into. I have limited tools and even less knowledge. I do have a lot of ambition, so I do have that going for me. It runs but there are a few issues and modifications I would like to make.
If you hate cafe racers, you might stop reading now and I'm okay with that. I'm not sure I have the technical skills to pull off the empty triangle but I do subscribe to the philosophy that if it works then it looks good. With that in mind lets talk about what I am thinking about doing.
It has an oil leak. I am literally banging my head against a wall looking for the start of this leak. I've tightened every bolt and screw and I have cleaned the bottom of the engine. So, I've decided to replace the seals on the engine. Also a lot of the bolts are stripped so they are being replaced with hex head.
I'm a little short for the stock ride height, so I was thinking shorter shocks.
I would like to go with a cafe style seat, but my girlfriend demands that she rides on the back at times. So, I was thinking a brat style seat. My question is that if I run shorter shocks and a brat style seat will I run out of travel and the wheel will hit the rear fender.
So the front of the motorcycle is actually out of the planning stages already. I know, you missed your chance for input. I went to a salvage yard and pulled the entire front end off of a 1977 gl1000. Dual brakes upgrade! So at some point I've gotta get the tapered steering bearings. New grips and handle bars.
I sort of want to take everything down to the frame. strip the old paint off the frame, and then repaint. Replace the seals while the engine is out of the frame. Repaint the tank, side covers.
Too ambitious? Thoughts on the shocks? I've been thinking about rear sets, thoughts on a brand? Type of handlebars? superbike? brand?
aaand pictures!
« Last Edit: August 19, 2012, 03:06:41 PM by bjonesin »
Offline krusty
Re: Project: Can't Get Right.
« Reply #1 on: August 20, 2012, 05:07:09 AM »
A leaking O ring for the neutral sensor had me scratching my head for a while as it was in a tricky place to trace oil back to it.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
« Reply #2 on: August 21, 2012, 11:26:45 AM »
Shorter shocks (alone) are not the best solution for lowering the ride height.  You will also need to adjust (lower) your fork height or the bike will be more difficult to turn in.  Make sure when you order new shocks that you take into account the combined weight of both you and your passenger, and the frequency with which you plan to ride 2-up.  You want the shocks properly sprung so you do not bottom out, but if you ride single the majority of the time you do not want the rear to be overly-sprung either.  You will need to compromise based on how often she rides with you.
If you are adept with a wrench, go for it.  If not, you may want to enlist some help or have an experienced wrench help you out.  You can get over your head, especially if you are pulling the engine.
Offline bjonesin
    • My Project
« Reply #3 on: August 21, 2012, 09:14:26 PM »
So I've started to clean and polish my front end. First I had to take it apart and wouldn't you know it, the speedometer hub is broken and the screw is stripped. Any good idea's on how to fix?
Sent from my DROIDX using Tapatalk 2
« Last Edit: August 23, 2012, 07:38:34 AM by bjonesin »
Offline bjonesin
    • My Project
Re: Re: Project: Can't Get Right.
« Reply #4 on: August 21, 2012, 09:19:49 PM »
This is advice seems correct. From what I've read it will make the bike handle poorly. Also, my girlfriend doesn't ride often enough to warrant taking her into account. She has already had enough say. I think I am going to modify the seat to overcome my lack of height.
Offline bjonesin
    • My Project
« Reply #5 on: August 23, 2012, 07:40:04 AM »
Do you guys have any neat upgrades for the wiring harness?
Offline LesterPiglet
  • 1977 CB550F2
« Reply #6 on: August 23, 2012, 07:52:05 AM »
The only thing I can think about the harness is make your own. I'll be doing this when the weather gets bad.....
Offline mono
  • Definitely no
« Reply #7 on: August 23, 2012, 07:53:06 AM »
no real need to upgrade the wiring harness.  the bullet connectors work fine.  you may want to clean all of the contacts and re-grease them with dielectric grease, though.   Some people do upgrade the fusebox to be push-in fuses as opposed to the cylinder fuses, though.
if you need to replace the harness, new ones can be gotten for a reasonable price.
Offline bjonesin
    • My Project
« Reply #8 on: August 23, 2012, 08:23:45 AM »
Here's a little clarification on what I was thinking. Has anyone installed fuse blocks? Is it worth the effort?
Is trying to tackle the wiring harness just an exercise in frustration? I know that some of my wires are spliced in and and look a little melty. My concern is that I am going to catch myself on fire driving down the road.
  • 1977 CB550F2
« Reply #9 on: August 23, 2012, 01:25:55 PM »
That headlamp looks empty compared to mine.
Offline JimJamerino
  • Yay! I'm a
  • Not rich enough to be "eccentric."
    • My CB650C build thread
« Reply #10 on: August 23, 2012, 06:00:46 PM »
It looks like you've already started tearing into it.  Is it a running bike as it is?  Are you an inexperienced rider?  If so, I'd just ride it for right now.  You said you've never owned a bike before, so in my mind, modifying a bike before you have much experience riding is a half-baked idea.  With an old bike like this, you're going to have plenty of opportunities to work on it before you start cutting it up (as evidenced by your speedo hub).  There's a lot of little things that can go wrong in a build, and it would be truly heartbreaking (as well as painful) if your first ride ended in a wreck because of a small mistake.
I think your plan is doable, and I have no doubts that you'll be able to build your vision, but baby steps are a good thing when you're working with a machine that has two wheels surrounded by air.
Mind you, this is my personal opinion and I am in no way trying to be your dad and tell you what to do.  Were I in your shoes, ride it if you can before you cut it up.
~ Jim
formerly "emperorspartacus"
There are old bikers.  There are dumb bikers.  There are no old, dumb bikers.
My CB650C rebuild http://forums.sohc4.net/index.php?topic=74212.0
Offline bjonesin
    • My Project
« Reply #11 on: August 24, 2012, 07:00:38 AM »
Thanks for your concern JimaJamerino, I really appreciate it. Its always good to have someone being a voice of reason. I'll answer your questions because there are probably people here that have the same concerns and questions.
Is it a running bike as it is?   Yes! I commute to work on it. I've been doing that since May. So I have some experience, and its been really hard not to start this project early.
The speedometer hub that you refer to is actually not on my bike, but part of a GL1000. I'm trying my damnest to not take my bike out of commission until the very last day of the riding season here in KS. I'm trying to screw up stuff thats currently off the bike and wont compromise riding.
I've had the opportunity to buy other bikes. Cheaper, newer bikes. I didn't because I wasn't in love with them. Riding those bikes, was fun, but doesn't bring the same joy that a CB750.
Offline bjonesin
    • My Project
« Reply #12 on: August 24, 2012, 07:05:23 AM »
Those with a keen eye might have noticed that my gauges are less than stock. When I bought the bike I was told a white lie that the gauges work, they just needed new cables. Cables work! Gauges do not, but luckily(Maybe?) after I bought the bike, he let me have some parts for it. Part of those parts where some spare gauges.
Let's play a game, who knows what gauges go on my bike?????????????????
  • 1977 CB550F2
« Reply #13 on: August 24, 2012, 09:48:06 AM »
I'm not sure about the 750 but I do know the 1977 550F2 had blue clocks.
Offline bjonesin
    • My Project
« Reply #14 on: August 25, 2012, 12:33:53 PM »
Bad news guys. I managed to screw up the bleeder nipple extraction.
Any suggestions on what to do?  I don't think I have a drillbit hard enough to drill through the extractor. Do you think it would be easier to just find another brake caliper at this point?
« Reply #15 on: August 25, 2012, 12:45:29 PM »
PM FFJ, he may be able to help you with that caliper...
http://forums.sohc4.net/index.php?topic=104370.msg1234888#new
Offline bjonesin
    • My Project
« Reply #16 on: August 26, 2012, 12:26:08 PM »
Thanks Steve-O, I sent FFJ a PM and the Price to get it drilled is about the price it would cost for me to pick up one at a junk yard next weekend. So, I think that is the plans as of right now. Plus, I wanted to see if I couldnt find a tank to learn to paint on. I'm going to spend the week trying to find someone closer to me with the ability to drill it out and see if they couldnt do it cheaper.  Not that FFJ wouldn't do a great job, I just kind of want to keep as much of it in my hands as possible.
Offline bjonesin
    • My Project
« Reply #17 on: September 06, 2012, 07:48:31 AM »
Does internet shopping count as working on the bike? I sure hope it does. In my case i spend time reading the forum, actually picking the exact part I want, and then price comparing. It's time consuming but hopefully keep my budget in check.
I went ahead and bought a used caliper off ebay. The seller has a seven day hold on all paypal orders.  Purgatory is stupid slow. Hopefully that will show up sometime next week.
A part that did show up is all the way from the uk!
I made the mistake of telling my boss at work. The next thing I know i need to have put then so I can show him.Before
Dont tell my girlfriend
So sad looking
Finished !
This project wasn't slated for when it happened. I know i will have to undo this work when i swap front ends but man are new handlebars great.  I don't feel like I'm 80 driving a goldwing anymore. So my bars hit my tank of course. Build new steering stops or can i adjust the bars so they dont hit?
So while reading the forum,  i discovered that on the late model F you can flip flop the footpegs and it moves them about 2" back. I tried this and got as far as taking the nut off the bolt that holds the footpeg on and discovered that the bolt was bent. Probably from laying the bike down. Any suggestions on how to get the bolt back in alignment or not worth the time?
Ive been sanding my front fork in preparation for paint. How fine should i go? I've heard since its being painted that 400 will work. Any suggestions on paint brand?
Offline bjonesin
    • My Project
« Reply #18 on: September 11, 2012, 06:48:03 AM »
It's been a few days and it's been a fight every step of the way. I ordered a hondaman ignition. I wired it up
It finally sputtered to life and i rode it around to make sure it was solid. my bike sounded better and i was pleased. I went out to start it the next day nothing.  Its like it wasnt getting spark. So i unhooked it all and Wired it back to stock. Still nothing. Checked all my connections and wired it back in. Pulled the sparkplugs out and kicked it to see if they were getting spark. They are. Im at a loss as to what to do now?????
Offline knowsnothing
« Reply #19 on: September 11, 2012, 11:15:25 AM »
- Check your battery
- Check fuel
Report back.
1978 CB750k Blue - for sale
Offline Mercutiojb
« Reply #20 on: September 11, 2012, 12:10:36 PM »
I have a 77 as well, and will keep an eye on this!
Offline bjonesin
    • My Project
« Reply #21 on: September 12, 2012, 09:36:48 AM »
So, I unplugged everything from the hondaman ignition, cut the female cover sleeves, cleaned all the connectors, went back to stock. First kick, roars to life. Sweeet! This may have been worth all the frustration, it sounds better than it ever has. So, of course I have to touch it again. Disconnect stock, hook Hondaman Ignition in. NOTHING! I think that the problem is the ground on my points cover. It is the only unknown left in this situation. I obviously don't think the ignition is broken, becuase I've gotten it to work once. The problem is clearly my battery, or the connections. I'll keep fighting with it until resolution.
My bar end mirrors arrived, and I installed the left one. Cut the tip off the existing handlebar grip and tighten down. Looks good. Cut the top off the grip. Hey dumb dumb, remember the throttle sleeve? nope. So the question now is, can i slide everthing up the handlebar to expose the actual handlebar or will the throttle sleeve not slide up that far? If I can't do I make an adapter to fit into the actual handlebar that sticks out far enough for the mirror to attach to?
« Reply #22 on: September 12, 2012, 09:48:07 AM »
I am running a hondaman ignition and haven't had any issues so far.   It was pretty much plug and play.  You might think about getting in touch with Mark (Hondaman) and see if he can help troubleshoot your issue.  He knows a TON and is more than willing to help.
The throttle sleeve should just slide up until a bend in the bar i would think. Its a hollow tube open on both ends.
Offline bjonesin
    • My Project
« Reply #23 on: September 12, 2012, 09:54:24 AM »
That is exactly what has me worried. If I can't figure out the things that are plug and play, then I should probably forget about anything more complicated than putting fuel in. I wanted to flounder around some more before I ask for real help from Mark. How am I ever supposed to learn anything if I get expert advice exactly when I ask for it!?! In all seriousness, I'm going to ask if I can't do it myself.
Offline bjonesin
    • My Project
« Reply #24 on: September 17, 2012, 09:48:47 AM »
Okay so I think I've got it wired up correctly but I'm still having some issues with start up. Maybe just cold blooded.
All though does anybody know if my points plate is supposed to jump a spark across it? Do i have some sort of short or grounding issue?  Is this why im having problems is that my spark isnt traveling down to the sparkplug but to my points????
