Author Topic: Sprockets  (Read 6107 times)
Offline Sitarz84
Sprockets
« on: August 19, 2012, 04:43:53 PM »
What kind of sprockets should I get with a 530 chain?
Right now I have a 630 chain
Offline cabrala
  • Super Duper
Re: Sprockets
« Reply #1 on: August 19, 2012, 05:05:48 PM »
Sprockets in relation to which bike!?!? Why don't you let us know what you're saddling first? Then, while waiting for replies here, do some solo research and look at a parts fiche to determine a stock setup (motogrid.com).
Finally, use the Google Custom Search on this site (upper left of page) to search for 530 chain setups for your particular CB. I'm not certain if sprocket teeth will change due to different chains, but my newbie senses tell me it could be possible with changes in pitch.
Good luck,
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
Need a better, newer points cover gasket? How about rubber washers for the headlight bucket? Click the link below:
http://forums.sohc4.net/index.php?topic=122308.0
Offline lucky
Re: Sprockets
« Reply #2 on: August 19, 2012, 05:31:51 PM »
A 17T-43T  would be very close to stock for the 1977-78 CB750.
But if you want high cruising speeds (65+) at lower rpm I would go with a 17T-40T combo.
You can get them at Yamatoya Motorsports. If you call them they will help you.
Offline Sitarz84
Re: Sprockets
« Reply #3 on: August 20, 2012, 04:07:14 AM »
1977 cb750f is what I'm riding...
Offline Sitarz84
Re: Sprockets
« Reply #4 on: August 20, 2012, 04:09:05 AM »
So the 17T-43T will work with a 530 chain?
Re: Sprockets
« Reply #5 on: August 20, 2012, 06:27:16 AM »
Its not the number of teeth that determines whether it will fit with your chain. You need 530 sprockets for 530 chains, regardless of the number of teeth. Its the width of the sprocket and distance between the pins.
Find the ratio of the 630 sprockets you have (14 and 43 are stock for your bike) is 3.07. To match that with 530 sprockets you'll need a 16t and a 48t (=3.0).
You may find that a 17/48 is comfortable. But you buy the sprockets for the chain size.
In makeing your switch from 630 to 530, i think you have to change your rear wheel drive plate as well. There are plenty of thread discussions on this.
All the usual suspects sell sprockets: motogrid; parts n more; CMSNL; Bike Bandit, etc.
Offline Sitarz84
Re: Sprockets
« Reply #6 on: August 20, 2012, 07:03:54 AM »
I have no idea what a drive plate is. I guess I'll be learning something new shortly.
thanks for giving me the sizes I need.
Re: Sprockets
« Reply #7 on: August 20, 2012, 07:21:29 AM »
The drive plate is the part of the rear wheel to which the rear sprocket is bolted. It is removable. The drive plate on the bikes like yours that came with 630 chain/sprockets sticks out more (or less, I'm not sure) that the drive plate on earlier bikes that carried the 530 chain/sprocket combo.
My understanding from reading threads of those who have made this conversion, is that you must change this drive plate as well so the sprockets will line up front to rear.
Re: Sprockets
« Reply #8 on: August 20, 2012, 08:11:30 AM »
This is true when fitting an early motor in a late frame. With the late motor in the late frame it won't be an issue.
Re: Sprockets
« Reply #9 on: August 20, 2012, 08:14:52 AM »
Aah, thank you.
Offline lucky
Re: Sprockets
« Reply #10 on: August 20, 2012, 08:17:07 AM »
You get #530 sprockets for # 530 chain. See how it works?
#530 is the pitch( distance between teeth or chain links).
Offline lucky
Re: Sprockets
« Reply #11 on: August 20, 2012, 08:20:10 AM »
Change the drive plate??? Do not know what you are talking about.
What is a drive plate????
All I have ever done is take off the old #630 sprocket and put on the new #530 sprocket. Done.
Re: Sprockets
« Reply #12 on: August 20, 2012, 10:02:12 AM »
Drive plate = sprocket carrier.
As to need, Scottly already explained it up above.
Re: Sprockets
« Reply #13 on: August 20, 2012, 10:53:40 AM »
No where near close!  :o
Offline lucky
Re: Sprockets
« Reply #14 on: August 20, 2012, 10:56:01 AM »
The 1977-78 CB750's had a higher 4th and 5th gear ratios than the earlier models.
I mentioned the 40 T rear sprocket if you drive on the freeway a lot.
The final gear ratios for the F model were 1.133:1 4th gear and 0.969:1 5th gear.
The final gear ratios for the K model were 1.097:1 4th gear and 0.939:1 5th gear.
Starting Engine #
CB750FE-2500004       F1
        new camshaft, carbs w/additional idle air. New pistons, compression ratio 9.2/1. New case w/o primary chain oiler. Final drive gear ratio 43/50 i/o 48/50. 4th gear on main shaft 31 i/o 30, 5th gear on countershaft 31 i/o 32
« Last Edit: August 20, 2012, 11:11:54 AM by lucky »
Re: Sprockets
« Reply #15 on: August 20, 2012, 11:10:58 AM »
K7 was 15/41= 2.7333. 17/43= 2.529. 17/40= 2.352.
Offline lucky
Re: Sprockets
« Reply #16 on: August 20, 2012, 11:15:36 AM »
You are right Scottly!  I stand corrected.
The OP has a 1977 F model but since we do not know the engine number it will be hard to recommend the best ratios for his bike without further info.
Offline lucky
Re: Sprockets
« Reply #17 on: August 20, 2012, 11:18:54 AM »
K7 was 15/41= 2.7333:1    17/43= 2.529:1    17/40= 2.352:1
Less confusing to me.
bollingball
Re: Sprockets
« Reply #18 on: August 20, 2012, 11:19:59 AM »
scottly +1 not close
 Out 10mm to line up with the front. ;)
 No surprise here. ;D Think potatoe pototoe :D
Sitarz84  Lots of good advice here. Just be carefull with any thing that starts with L. ::) ::) Like length of chain. ;) Can you read between the lines?
Ken
Re: Sprockets
« Reply #19 on: August 20, 2012, 11:21:28 AM »
I believe the late Fs were 15/43 = 2.866
17/48= 2.823
Offline lucky
Re: Sprockets
« Reply #20 on: August 20, 2012, 11:23:02 AM »
Scottly...Do you know the final sprocket ratios for the K8?
Offline lucky
Re: Sprockets
« Reply #21 on: August 20, 2012, 11:40:07 AM »
Ken
My 1978 K8 did not have a drive plate.
Offline lucky
Re: Sprockets
« Reply #22 on: August 20, 2012, 11:42:37 AM »
Ken
Ok...I made a mistake.
How much mileage can you get out of it? Cheeeeeessssshhhh!
Re: Sprockets
« Reply #23 on: August 20, 2012, 11:54:58 AM »
You've made 9 worthless posts so far on this thread. How much more mileage can YOU get out of it? ::)
Re: Sprockets
« Reply #24 on: August 20, 2012, 12:24:17 PM »
Ken
It didn't have a sprocket carrier either.
1978 K microfiche calls it a "flange, final driven". = potatoe = pototae = potato
« Last Edit: August 20, 2012, 12:25:49 PM by MCRider »
