Author Topic: CB750 motor rebuild question, output shaft drip pan  (Read 1006 times)
Offline Eydugstr
« on: August 20, 2012, 07:46:47 AM »
While rebuilding a tranny on my CB750, decided to replace the original output shaft (with the chain oiler) with a later model one that is just a solid shaft.  Noticed that the drip/catch pan is just a hair to long to fit into the end of the shaft like the original, so my question is this - In this situation, would you guys recommend grinding off the end of the end of the pan to where it'd still put oil onto the solid shaft?  Or just get rid of the pan altogether?  Thanks.
Offline markb
  • When I finish my current project I might be a
Re: CB750 motor rebuild question, output shaft drip pan
« Reply #1 on: August 20, 2012, 11:22:55 AM »
Are you talking about item 10?  Others may have a different opinion but if the shaft is solid (or plugged), it’s not going to do anything so not required.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline Eydugstr
« Reply #2 on: August 21, 2012, 07:13:35 AM »
Yes, that's the one.  In Hondaman's book, he also said it can be removed, but also mentioned that the shaft tends to run a little dry.  Did the later motors just eliminate using the pan?
