Author Topic: drag bars on a 750- smaller mastrer cylinder???  (Read 1380 times)
Andrew Foss
« on: June 27, 2006, 01:29:37 PM »
hey everyone,
i just finished an install of new drag bars, which are awesome, except that the master cylinder does not fit, leaving my brake handle at a weird angle, and my right mirior totally useless. i was wondering what others have done in this situation. thanks,
-andrew
Offline cbjunkie
  • ...know what i'm sayin'?
Re: drag bars on a 750- smaller mastrer cylinder???
« Reply #1 on: June 27, 2006, 02:01:22 PM »
I know this is not going to be easy to see, or understand, but what i did was to run the knob of the MC between the handlebar mount and the underside of the tachometer - this tucks the MC right up on the bar mount - then, and this is the trick, the banjo twists down between the speedo and the tach - the line runs straight down to the caliper.
the handles are at slightly different angles...it took me about one hour to get used to it...
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #2 on: June 27, 2006, 02:48:04 PM »
You can go with a modern / remote master setup like I have.....
You can get a used one offa newer sportbike for cheap...
Offline STLrocker
  • whiskey bent and hell bound
« Reply #3 on: June 27, 2006, 06:56:08 PM »
i have a newer MC from a yamaha. it is shorter and the banjo bolts to the front. lots more room to work with this way.
Offline KB02
« Reply #4 on: June 28, 2006, 04:59:42 AM »
I did the same thing and got a newer, modern, MC off of ebay. It works and fits great.
As for the mirror, get yourself a set of bar end mirrors. They work great. I love mine.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
don76
« Reply #5 on: June 28, 2006, 05:17:21 AM »
I have straight drag bars/broomstick on mine, with a set of 6 inch dog bone risers.  Had the same problem.  Somplace along the line, someone had mentioned that Buell has 7/8ths inch bars.  I checked it out, and they work great.  I was able to eliminate the pressure switch for the brake lights, because the switch was attached to the master cylinder.  I ran a braided/stainless line right from the m/c to the caliper, and the mirror mount on the m/c worked fine.  Good luck
Don
