Author Topic: cb 750 k4 HEADLIGHT BRACKETS  (Read 788 times)
Offline fartypants
  • It's always too soon to quit !
« on: August 21, 2012, 08:40:44 AM »
Hi folks
         Will the headlight brackets from a honda cb750 k2 fit a k4 as they are different part numbers, honda has discontinued the k4 ones but k2 ones are still available, i think the only difference is the indicator mounts
cheers
Andy
« Last Edit: August 21, 2012, 09:09:37 AM by fartypants »
1930 sunbeam model 8
1936 bsa bluestar 500 q21
1939 velocette mac
1922 triumph model h
2013 victory vegas
1975 Honda cb750 k6
1959 bsa bantam
1956 ariel hunt master
Offline Raul CB750K1
Re: cb 750 k4 HEADLIGHT BRACKETS
« Reply #1 on: August 22, 2012, 12:20:59 AM »
Without knowing either model in full, I would bet they headlight ears can be used in either model. My K1 has no indicator mount - the indicator stem is used to hold the headlight in place. But the difference in part number can be just because of the color.
K2 onwards had chrome headlight ears, therefore, the difference in part number can be because of the different location of the indicator mount. I would do this: check the upper and lower triple tree part number - if they are the same for K2 and K4, then the distance between upper and lower is the same, then the headlight ears must be compatible.
Offline fartypants
« Reply #2 on: August 22, 2012, 12:52:09 AM »
Thanks Paul i am sure your right, i have just ordered a set of k2 ones from david silver and i will report back to the forum if they fit ok and like you i think its just the indicator mounts.
cheers
Andy
1939 velocette mac
2013 victory vegas
1975 Honda cb750 k6
1959 bsa bantam
Offline kmb69
« Reply #3 on: August 22, 2012, 01:42:09 AM »
Yes, they fit the trees perfectly.
« Reply #4 on: August 22, 2012, 01:46:31 AM »
I'm still chuckling at your forum name........... ;D
