Author Topic: When powdercoating--watch out for rubber mounted bushings.  (Read 4773 times)
Offline SOHC_guy
  • 750 K0 purchased new
« on: August 22, 2012, 06:12:04 AM »
I decided not to remove the shock mounting rubber bushings on the swing arm of my 750 project before powdercoating Felt that I would destroy them in the process. Now I wish I had removed them anyway
'cause they are a little "cooked". I learned after the fact that powdercoating is a 400 degree process.
Perhaps someone will learn from my mistake.
Oh, BTW, any aftermarket replacements for these?
"Whether you think you can, or think you can't, you are absolutely right"  Henry Ford
Trust is the key--to everything in Life.
1970 K0  "Sandy"
1975 850 Norton Commando Interstate
Re: When powdercoating--watch out for rubber mounted bushings.
« Reply #1 on: August 22, 2012, 06:22:09 AM »
I think they are still available from Honda.
Offline srbakker
  • Spam & Eggs
« Reply #2 on: August 22, 2012, 06:41:11 AM »
Yup, I replaced some recently via ronayers.com.
1975 CB750 K5
2007 Triumph Tiger
2007 Triumph Speed Triple
1971 Kawasaki F7 175 Enduro
Offline CycleRanger
  • No comment about being an
« Reply #3 on: August 22, 2012, 07:24:10 AM »
Yes, still available from Honda.
RUBBER, RR. SWINGARM   40548-268-000  about ~$5 each.
Push them out toward the inside. The holes are tapered.
I'm surprised the powdercoater left them in.
The place that did mine was very clear that all grease, paint, rubber, etc. had to be removed prior to bake to avoid contaminating their oven.
