Author Topic: Clutch not fully engaging when cold  (Read 968 times)
Offline Tamothy
« on: August 22, 2012, 09:21:47 AM »
'77 CB550F
New clutch plates a couple hundred miles ago. . .
When I have just started the bike, if I engage the clutch and shift to first gear the bike lunges forward and stalls.  It behaves like I have put it into gear without engaging the clutch.  After it has ran for a short time, this behavior is not present.
What is the cause?  Improper adjustment?  Is the clutch without much oil at start-up?
If adjustment I will add this info:  the bike is always a bit sluggish when releasing clutch in first gear from a stop.  I have assumed this is due to 1) past due timing tune-up 2) uni pods on otherwise stock machine 3) bench-synced carbs
This bike sat for a long time and I have been working my way through it.  I got to the point of final tuning and got busy with other things.  But, I have been riding it and it is a blast.  So you have an idea of where I am:
-rebuilt swingarm, forks, carbs, brakes
-oil pan and screen washed
-valves adjusted
-new clutch plates
-new throttle and clutch cables
-lots of new OEM gaskets and fasteners ( like all sane minds, I HATE slightly stripped, crummy-looking screw heads)
-new chain and sprockets
-new fuel lines
-new battery
-new Avon Roadrider tires
-stock header w/ new Mac muffler
I need to learn more about points and straighten out the timing.  I should put new plugs in it (why the heck have I not done this simple task yet?)
I just got new airbox connectors from a mate on this forum who is reproducing them.  I have the stock airbox and need to get it on and sorted.  Then, carb sync.
The bike has about 15k miles on it now.  I know I gave alot of info, but know it is easy to guess at someone's mechanical ills if you can see the picture a bit!  Also, quite the brain knocker for me to recollect.  I should keep notes, but I don't!
Current Bikes:
'76 XL350 - just picked it up, will be my forest road/camping machine
'77 CB550F - going to get it top-notch, like ride across the country top-notch, like it is 1980 and it has 12k miles with a loving, original owner
'82 CB900F - my (sometimes) daily rider
'74 RD350 - 6k miles, straight out of a barn, waiting for restoration
These old bikes are teaching me a big boat load!  I love 'em!
Offline LesterPiglet
  • 1977 CB550F2
Re: Clutch not fully engaging when cold
« Reply #1 on: August 22, 2012, 09:27:28 AM »
What grade oil are you using?
Offline Tamothy
« Reply #2 on: August 22, 2012, 09:30:19 AM »
Well Lester, I can't recall at the moment.  Probably what the manual states. . .perhaps 10w-40, 5w-30. . .crap, I don't know!  Lucas Oil. . .nope, still don't know.
Current Bikes:
  • 1977 CB550F2
« Reply #3 on: August 22, 2012, 09:36:52 AM »
If the oil is too heavy it will make the clutch drag until it warms up and thins out. Has the clutch been adjusted per the manual?
Offline Tamothy
« Reply #4 on: August 22, 2012, 09:43:17 AM »
I truly think it has 10w-40 right now.  Is that heavy?
Yes, I have adjusted the clutch per manual.
« Last Edit: August 22, 2012, 09:51:05 AM by Tamothy »
Current Bikes:
  • 1977 CB550F2
« Reply #5 on: August 22, 2012, 09:52:52 AM »
That's fine. Has it been like this since you rebuilt it. Ridges develop on the clutch basket preventing proper operation of the clutch. These can be filed smooth.
« Last Edit: August 22, 2012, 09:55:22 AM by LesterPiglet »
Offline Tamothy
« Reply #6 on: August 22, 2012, 10:12:02 AM »
While clutch was disassembled I looked for such signs and the basket looked good.  Of course, it was my first clutch to rebuild so maybe.
Current Bikes:
