Author Topic: Mistery CB750 carbs  (Read 2678 times)
Offline Raul CB750K1
Mistery CB750 carbs
« on: August 22, 2012, 01:44:08 PM »
Some years ago I bought from a german ebay seller a set of carbs that were listed as "K2". I have a K1, but I just wanted the rack to have an spare, in the grounds that I could always use the right jets if need arise.
They have been stored during all this time, and I thought that I probably should just have to let them go. So I opened the bowls -had to use the rubber mallet, didn't opened them when I got them- and, under a varnish layer, I found 120 and 40 jets. I didn't take any picture of my carbs when I rebuilt them, but if memory serves me, that's the right configuration for the K1, right?
Offline CycleRanger
  • No comment about being an
Re: Mistery CB750 carbs
« Reply #1 on: August 22, 2012, 02:24:42 PM »
Are the carb bodies marked 7A?
Offline Kevin D
  • SE Michigan
« Reply #2 on: August 22, 2012, 03:44:20 PM »
120 and 40 jets. that's right for the K1?
yes - for stock setup
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline farmertom
  • Owner of many cb750s
  • MBS - anonymous
« Reply #3 on: August 22, 2012, 04:36:59 PM »
'76 cb750a
'77 cb750a
...and many K's
« Reply #4 on: August 23, 2012, 12:22:43 AM »
Offline phil71
« Reply #5 on: August 23, 2012, 12:36:54 AM »
jeeze, that bowl looks like a tequila sunrise.
« Reply #6 on: August 23, 2012, 02:46:36 AM »
It was not the worst of the four.....
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #7 on: August 23, 2012, 03:01:51 AM »
I had a set of bowls that looked exactly like that. Here's what I did with 'em.
http://forums.sohc4.net/index.php?topic=61168.msg717941#msg717941
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
« Reply #8 on: August 23, 2012, 05:57:53 AM »
1971's also had the brass floats which you have.
« Reply #9 on: August 23, 2012, 06:38:47 AM »
You mean that just with soaking in vinegar and letting sit overnight you get that result?
Offline Frostyboy
  • Circa 1951
« Reply #10 on: August 23, 2012, 10:04:01 PM »
Correctomundo Raul. O'night soak & a quick blast of carb cleaner the next day. Cool hey?  ;)
White vinegar btw.
We haven't met yet.
[CB550F1]
Offline goldarrow
  • one day, i'll be an
Mistery CB750 carbs
« Reply #11 on: August 23, 2012, 11:49:07 PM »
Do not soak carbs in vinegar, it will eat your aluminum.  You have been warned.  Well, if you don't use too much of vinegar, I guess it's alright.
« Last Edit: August 24, 2012, 12:00:37 AM by goldarrow »
CB550 K0
« Reply #12 on: August 24, 2012, 12:49:19 AM »
Damn! What should I do then?
Offline goldarrow
Mistery CB750 carbs
« Reply #13 on: August 24, 2012, 12:54:49 AM »
Pine-sol or simple green mix with water, soak over night. Blow out with compressed air. Nice and clean with fresh smell
CB550 K0
« Reply #14 on: August 24, 2012, 01:56:02 AM »
Go to a car paint shop and get 5 ltr of "Gunwash" its the nearest now available to Celulose Thinners. MUST BE USED IMMERSING THE BITS IN A SEALED CAN OR JAR othervise all the "Goodness" evaporates, plus no smoking and not in the oven as it goes bang quite easily!!
« Reply #15 on: August 24, 2012, 02:29:29 AM »
the bodies are a zinc alloy,the bowls and top cap are aluminium,the zinc casts easier for those intricate passages in the body,70s tech stuff.
Offline Frostyboy
  • Circa 1951
« Reply #16 on: August 24, 2012, 02:45:35 AM »
Vinegar is approx 5% acetic acid, pure acetic acid is transported in aluminium tanks.
I only used it to clean the bowls. I had the rest of the carbs soda blasted.
We haven't met yet.
[CB550F1]
« Reply #17 on: August 24, 2012, 05:06:25 AM »
Anybody out there still use Carb cleaner ?? Guess I am just to old  ???
Offline Tews19
  • I am no
« Reply #18 on: August 24, 2012, 05:20:51 AM »
Eric I saw that at an auto store. You recommend? I want to learn the 750 carbs and have a set sitting here doing nothing. If I mess up not that big of a deal.
1970 Honda CB750 survivor.
« Reply #19 on: August 24, 2012, 05:38:29 AM »
The carb cleaner nowadays is not as 'hot' as the stuff they used to make Nick but it has always worked well for me. After a good soaking and cleaning it can be rinsed out with water and then all the passages blown out well with compressed air. Follow up with some areosol carb cleaner to make sure passages are clear,little more air blow and be done.
