I have an Ebay 836 kit on a K4, engine. With the cylinder installed, not bolted down and a stock cylinder to block gasket. The pistons are slightly out of the hole leaving less than the gasket thickness for clearance. I know some measuring is needed but how much clearance should I be looking for?
And no, I didn't check before putting on the rings dangit.
