Author Topic: setting up the point  (Read 711 times)
Offline goldarrow
  • one day, i'll be an
« on: August 23, 2012, 07:51:14 PM »
i know there has been many threads discussing this already but can't seem to find any posts that answer my questions.  so, here goes....
1975 cb550  setting up the point following the manual seems very simple, but trying to see when the crank turns until the point contact opens widest could be tricky to the eyes.  after several turns, i notice that when the points open up the most, the crank is at 15 degrees ATDC.  so i used that as a reference to adjusting the point. someone please correct me if i'm wrong. manual spec is 0.3mm - 0.4mm.  do the same procedure for point 2-3.
CB550 K0
Offline Dimitri13
  • 1974 CB550K
Re: setting up the point
« Reply #1 on: August 23, 2012, 08:19:24 PM »
Correct.
« Reply #2 on: August 24, 2012, 12:21:14 AM »
if your cashed up for a decent electronic its worth considering,you have to time both point sets and get them accurate,then fiddle with them from time to time,you can use the stock coils with many electronic conversions.
