Author Topic: Time for Reassembly, Help  (Read 522 times)
Offline NewOldSchool
  • Apprentice
« on: August 24, 2012, 10:40:41 AM »
Beginning to button my top end back together. I had the head rebuilt and I am reassembling the valve train.
Do I need to use assembly lube on the rocker shafts, cam, etc or can I generously lube them up with oil? I am reusing all the valve train pieces and stock cam on a 30,000 mile engine. All of them are within spec and in great condition.
Not putting miles on your bike is like not having sex with your Girl Friend so she'll be more desirable to her next Boy Friend.
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
Re: Time for Reassembly, Help
« Reply #1 on: August 24, 2012, 01:50:16 PM »
Well I have used assembly lube on mine...as I figured - if I don't get any or much oil circulation going for a bit - the ass. lube hangs around longer..whereas your "large quantity" of oil splatteerd around is gonna dissipate real fast. I did a bit of both. Assembly lube on cam lobes etc and splattered oil around the top as well.
Mark
Offline Old Scrambler
« Reply #2 on: August 24, 2012, 02:06:14 PM »
With the head torqued to the high-end of spec ........I let the motor sit for a day and retorque before assembling the rest of the cam tower parts. On final assembly I use a drop of blue Lock-Tite on those cam-tower cap-bolt threads
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
  • Apprentice
« Reply #3 on: August 24, 2012, 02:25:06 PM »
Thanks to both of you.
Offline lucky
« Reply #4 on: August 24, 2012, 02:53:24 PM »
Excellent advice since it cannot be done once it is in the frame.
