Author Topic: cb550 cam problem  (Read 540 times)
Offline johnnylaw
cb550 cam problem
« on: August 24, 2012, 01:54:07 PM »
hi all,
so its been a while since i've done anything to my project bike, but i recently started back up on engine assembly.  i went thru the head and found something out of place.
I have wear on two sets of rocker arms and funny wear on my camshaft in the same positions.  i then noticed that the rod that the rocker arm rotates on is offset on the holes in the ends of the head cover.  I've read that in early 550k's it was common for these rods to spin in the bores, although im not sure if my bike is applicable to this problem.  is this what happened?  am i out of luck and need to find a new cam and head cover?
thanks in advance for any help you can provide.  i have pics but for some reason this wont allow me to upload.
-John
Offline Dimitri13
  • 1974 CB550K
Re: cb550 cam problem
« Reply #1 on: August 24, 2012, 02:01:07 PM »
From what I read in my shop manual, you're supposed to replace the cam cover wit a 77-78.
Offline johnnylaw
« Reply #2 on: August 24, 2012, 02:04:34 PM »
Update: according to motorcycleproject.com/motorcycle/text/headgask.html my engine is applicable to the rotating rod problem.
Dimitri, which manual is that?
Offline Dimitri13
  • 1974 CB550K
« Reply #3 on: August 24, 2012, 02:07:40 PM »
Clymer and the manual I downloaded from here.
