Author Topic: Will loose studs cause head to leak?  (Read 3067 times)
Offline danfr
    • Apollo Motorcycles
« on: August 24, 2012, 09:44:18 PM »
Hey Guys,
I'm rebuilding my head for the second time due to a solid leak on my right side. I'm thinking it could be from the front right cylinder stud being completely loose. So I might as well tighten (and check the rest!) to spec.
I looked in my manual and couldn't find the spec. I know 750's are 15-18 ft pounds (which seems REALLY high?).
Do you think having a backed out/super loose stud would cause a head gasket leak??
Thanks
Daniel
« Last Edit: August 25, 2012, 09:27:17 AM by danfr »
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
Offline camelman
  • Man... Myth... Legend
Re: CB350F Stud Torque?
« Reply #1 on: August 24, 2012, 11:48:24 PM »
14 to 16 if my memory is correct.  No books handy though.
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline danfr
« Reply #2 on: August 25, 2012, 12:45:39 AM »
I found a thread that said 8 ft pounds for the 750. I decided to play it safe and torqued it down to 8. I know they are prone to stripping out.
Hopefully that is the only issue causing the leak. I'll check the cylinders with a straight edge tomorrow. I chased all the stud threading while I was at it. Fingers crossed!!
Thanks
Daniel
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
Offline danfr
Re: Will loose studs cause head to leak?
« Reply #3 on: August 25, 2012, 09:29:30 AM »
has anyone else had a head leak from loose studs?
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
Offline KB02
« Reply #4 on: August 25, 2012, 09:59:56 AM »
That's what I am hoping has been my problem. I just re-torqued my head. Now I have to time the cam and button it all back u and go from there.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline lucky
« Reply #5 on: August 25, 2012, 10:04:37 AM »
Some confusion here. Do yo mean a loose stud or a loose nut on the stud???
Also cam timing is set when you install the cam into the cylinder head with all of the correct marks lined up.
Setting your engine timing with the points is electrical timing.
Two separate things.
Offline danfr
« Reply #6 on: August 25, 2012, 10:16:04 AM »
Please let me know how it runs! Thanks
I mean loose stud into the lower case.
(I've rebuilt a few CB's and haven't had any issues set up the cam timing).
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
Offline lucky
« Reply #7 on: August 25, 2012, 10:27:18 AM »
Can you turn the stud with your fingers? Is it stripped?
« Reply #8 on: August 25, 2012, 10:31:35 AM »
Loose lips sink ships  ;D
Offline danfr
« Reply #9 on: August 25, 2012, 10:37:55 AM »
I could turn it with my fingers. I tightened it up to 100 inch pounds. (8.5 foot pounds) and checked all the other studs to see if they were a minimum of 100 inch pounds.
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
« Reply #10 on: August 25, 2012, 10:40:01 AM »
Sure, but there are multiple other reasons for a head leak also.
Offline danfr
« Reply #11 on: August 25, 2012, 10:53:22 AM »
I resurfaced the head and cut the valve seats. New head and base gasket.
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
« Reply #12 on: August 25, 2012, 11:28:19 AM »
To name a few: Stud oil return seals and rubber pucks under cam towers. Cam tower studs leaking through/around threads.
Offline danfr
« Reply #13 on: August 25, 2012, 11:42:28 AM »
My bad, it's a 350f so no towers with troublesome pucks underneath.
I put in new rubber seals around the dowels between the head and cylinder. I'll wip it back together tonight and see what happens.
« Last Edit: August 25, 2012, 12:38:11 PM by danfr »
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
Offline lucky
« Reply #14 on: August 25, 2012, 11:58:58 AM »
What is it you are trying to say????
« Reply #15 on: August 25, 2012, 03:23:18 PM »
Loose nuts sink head?!  ;D
