Author Topic: disc brake to drum brake  (Read 1734 times)
joe750
« on: August 26, 2012, 05:58:11 AM »
I just picked up another 750 this weekend. Its a 1976 super sport and its a beaut.
However, the rear disc brake just doesn't appeal to me. I'm going for the cafe look with this one and i like the simplicity of the rear drum.
If I was to change the wheel to drum brake, do I need to have a different spacer in between to fill out the gap like on my hardtail or what?
Offline JamesM
Re: disc brake to drum brake
« Reply #1 on: August 26, 2012, 08:23:32 AM »
I'd like to know too, I want to put a drum in the front so I can use a throttle tube set up on the left instead of a lever.
Current Stable:
1972 CB750
1973 Shovel
1978 CB750
1977 KZ750T
1996 Shadow VLX
Offline Lostboy Steve
« Reply #2 on: August 26, 2012, 11:42:29 AM »
I love the way that giant drum looks on the race bikes. I'd do it!
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline danfr
    • Apollo Motorcycles
« Reply #3 on: August 26, 2012, 12:00:25 PM »
Please keep me in the loop with spacing! I'm working on a 750 with a 350 twin front wheel. I'll definitely need to figure out the proper spacing.
Cheers
Daniel
Apollo Motorcycles
71 Commando
74 CB750K
74 CB350F
Offline greenjeans
  • 1972 CB750K2
« Reply #4 on: August 27, 2012, 01:52:37 PM »
Just pick up a rear wheel off ebay.   You should be able to find one for $50 bucks.    Then you can put the whole thing in your frame to see what size spacers that you'd need.   Not sure if the swing arms really change too much besides the mounting points for your calipers etc.    You might get lucky and it will bolt right up.      Then, you'll just need to weld a tab on your swingarm for the brake stay.   Or...just buy a swing arm for a 69-76 and a rear wheel for the same and you're done.
The front is pretty easy as well to change to a drum.   You'll need a rim that is drilled for a drum (spoke angles are different than the disc rim)
Just a matter of spacers to center the hub.    You'd use the caliper mounting bosses to mount the stays.
You can probably use the axle from the CB750 for the front drum - you'll just need spacers.   Shoot me a PM.   I'm putting a gigantic 4LS drum brake on the front of my latest CB750.    I had to have the brake plates machined a little as well as the axle.   Local machine shop took care of it for $50.
Offline shinyribs
« Reply #5 on: August 27, 2012, 02:26:03 PM »
I have a 76 f that had comstars and rear discs when I got it. I did the same swap on mine. The rear drum uses a different stay rod than the discs. I got a 75 k swingarm with a drum wheel and just bolted it on. You can Fab up anything to work. But if you want true bolt on, you need a drum brake swingarm.
The darn fool didn't know it couldn't be done...so he went ahead and did it anyway.
My Hackjob build- http://forums.sohc4.net/index.php?topic=106103.0
