Powdercoat set me back a few days- then I get a phone call today an they tell me they ran out of the powder I originally picked out. How do you run out of something when you had 15 days knowing thats the color I picked out. Went with hammertone black
didnt get it back today until 7pm so didt get as much done as I wanted.
Still to do
front an rear brake stay, brake rod- check
throttle/brake/clutch cables grips an thottle housing
carbs-tune- uni pk3
sprocket cover -check
finish wiring- check
install coils- check
set timing
oil
kicker/brake,shifter levers -check
still need toggle switch headligh bulb brass fitting for fuel tank
sure im forgetting few things
thanks for looking
another set back carb boots came out of the part pile an they are for a 77-78 I need the early models so another 53.00 an a few more days waiting on parts. give me some time to redo my seat finish off the list double check everything
