Author Topic: Cam tension adjuster  (Read 971 times)
Offline Sdsbassist
  • Gus, Austin, MN.
« on: August 27, 2012, 10:41:24 AM »
Narrowing top end tick. When the cam tensioner is out, and the bolt loosened, should it be able to be moved back and forth?
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
bollingball
Re: Cam tension adjuster
« Reply #1 on: August 27, 2012, 10:49:45 AM »
What motor?
bollingball
« Reply #2 on: August 27, 2012, 11:06:28 AM »
Is this the one?
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #3 on: August 27, 2012, 02:50:50 PM »
Yes
Gus, Austin, MN.
« Reply #4 on: August 27, 2012, 03:45:16 PM »
What does "when the cam tensioner is out" mean? what is out of what? You'll need to be more specific. The entire unit is the tensioner. The plunger is a ...well... plunger. (aka "push bar")
Yes, when the bolt is loose the plunger can move back and forth inside the housing. When the housing is on the cylinder, you loosen the bolt at the proper point of crank rotation, the plunger pushes forward against an idler wheel tightening the chain. Then you lock the plunger there with the bolt.
If you mean the tensioner (housing and all) is in your hand, and the bolt is loose, the plunger doesn't move? Iin that case it is stuck. This happens. You'll need to remove the bolt completely, pull the plunger out of the housing. Inspect it for burrs and corrosion. Polish the shaft. It should move smoothly and with little effort other than overcoming the spring. There is a seal in the housing that will provide a little resistance. But the plunger should not be stuck or it won't do the job as indicated in my first paragraph.
« Last Edit: August 27, 2012, 03:47:01 PM by MCRider »
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #5 on: August 27, 2012, 04:40:34 PM »
Got it. Thanks guys.
Gus, Austin, MN.
